Best way to install decals ?
Old May 22, 2006 | 08:00 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
I have 2 install some replacement decals on my car.
What is the best way so they stay on there 4 sure.
I´m glad 4 your help
Old May 22, 2006 | 08:46 AM
Mr. TurboTA's Avatar
Make sure the car is clean (where you will be placing the decals), and I also use a special dewaxer/degreaser from the auto paint stores. Make sure it's dry, and I also place peices of masking tape where the ends and bottom of the decal will go. I peel off the backing and very slowly, install the decal, using a squeegee to remove any air bubbles, and to firmly get the decal to adhere to the car.
I do the install dry, with no soapy water. But, you can use soapy water if you want.
Good luck with the install!
George
Old May 22, 2006 | 09:40 AM
HotRodLarry's Avatar
Car: '83 Z28
...Or you could have some one else do it...I found a local vinyl shop that is going to replace my factory Z28 stripes. Can't wait to see how good they turn out.
Old May 22, 2006 | 10:35 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
thanxs 4 your answers.
2 more questions What is the soapwater for ? What kind is the best ? Can i also use window cleaner ?
I´ve heard that some people also work with some kind of gasoline called "petroleum" . What is that good for ? Just to clean it ?
We don´t have 2 many good shops here in germany 2 do that kind of work.
U guys in the states are in heaven when it comes to stuff like that.
At one place they told me they wouldn´t even touch an american car
Old May 22, 2006 | 10:46 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
the soap water allows you to position the decal and move it around to get it exactly where you wanted without having to try to peel and restick.
I've used just dishwater soap in a spray bottle mixed with water.
I wouldn't rub gas on my paint. You can use rubbing alcohol, isopropenol, to make sure the surface is clean before putting the decals on.
Old May 23, 2006 | 01:01 AM
skunk66's Avatar
Car: Trans Am
Engine: Crossfire
So one last question about the wet version. After the decal is on the right spot. How long do i have to wait to take the protection skin of ? Is it better 2 use a hair dryer so it attaches better ?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Apr 25, 2017 07:14 AM
ken3983
Aug 23, 2015 07:31 PM
