How to apply stripe kit?
Old May 27, 2006 | 11:54 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have a stripe kit for my car. There is a peel away backing and the bottom side of the stripes have sticky stuff. Also, there is about 1/2" clear portion extending past the black stripes all around.
It seems very difficult for me to apply long stripes and not trap air.
And I wonder if I should trim off all of the over-run clear portion.
Also, I wonder if I should cut out each stripe separately, and apply.
Right now the right side stripe is on the same piece of backing paper as the left stripe,, both stripes are 1" apart, separated by the backing paper but joined via the clear see-thru portion.
I can use some help and advise here, please and thank you.
Old May 27, 2006 | 12:55 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Use a water mister with a couple of drops of washing up liquid mixed in. Spray the panel liberally and also the decal on the sticky side. Place the decal on the panel with the backing sheet still on, you can now slide it around to your hearts content until you get it right. Caution, don't do this in extremely hot or cold climates. If you have any air bubbles use a credit card or similar to squeeze them out. Wait until the decal has fixed before removing the backing sheet, usually the next day in Britain but if it's warm enough where you are after a couple of hours. Stand back and admire your work and pat yourself on the back.
Old May 27, 2006 | 02:58 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I've been doing this for a living for 6 years. Wait for a warm day, its not even worth it if it is frigid out. Use a water based solvent as stated and spray tons of it underneath before you lay it down. What I would do is have a friend hold down one end, and you take the far end down to the other side of the car and pull it taught and lie it down at eye level to get it perfect.
When you are done that, run your finger down it to get the air bubbles out, this is what the solution is for, it will allow the bubbles to slide out. After it has set for a little while, go back over it with a rubber squeegee, or a credit card if one isnt available, and squeegee the hell out of it. Just make sure not to scratch your car in the process.
Old May 27, 2006 | 03:12 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Would glass cleaner be acceptable for the soapy solution?
Old May 27, 2006 | 04:02 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
Nope! Use a soapy solution only but not too much detergent.
Old May 27, 2006 | 04:07 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
just take water and add a little soap
Old May 27, 2006 | 05:14 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you very much for all the help!
Old May 27, 2006 | 11:57 PM
Actually where I work, we've used Windex before with surprising results. You'd think that it would damage the sticky element of the vinyl but it doesnt.
devilschariot
Feb 25, 2016 03:08 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Randomtask2
Sep 7, 2015 05:06 PM
