1988 formula 5.0 5 speed hard throttle
Old Sep 6, 2015 | 01:26 PM
Randomtask2's Avatar
Car: 1992 Pontiac Firebird Formula
Engine: 5.0 305 tpi
Transmission: T5 (5 Speed) lol
Axle/Gears: stock posi
The throttle is very hard on this and when manually turning it under the hood. It makes a lot of noise. Initially when applying throttle. It's sticky and makes noise. But after its applied it's like butter but going back down to idle everytime I want to bring it back up its hard. So is there any point of which I can lube or anything. So it's throttle action won't stick or be so hard to apply off the line. Or do I need to get another throttle body. Anyone with information helps. Thank you
Old Sep 6, 2015 | 02:53 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: 1988 formula 5.0 5 speed hard throttle
have you unhooked the cable(s) to be sure it is in the throttle body its self? if not start there ... if so take it apart and clean or rebuild it ... is it tpi or tbi?
Old Sep 6, 2015 | 03:03 PM
Engine: 5.0 305 tpi
Didn't take off the throttle cable yet. It's tbi. But the noise comes from the throttle body spring itself.
Old Sep 6, 2015 | 03:07 PM
Barlow8869's Avatar
does it move free with the spring off?
Old Sep 6, 2015 | 03:11 PM
Barlow8869's Avatar
if it were me, i would take everything off the shaft that i could until i found out what it was ... if it is just down to shaft and the plates on the shaft and still doing it, i would think about a rebuild kit ... also, have you looked in to make sure the plates are not closing to far and sticking in the throttle body? ... also it it 700r4 or t5?
Old Sep 6, 2015 | 03:50 PM
Engine: 5.0 305 tpi
I haven't removed anything yet. I just decided to touch base on this topic. It's a t5 and it's very annoying because I can't give it the proper amount of gas off launch because of this throttle issue so I borderline end up launching it lightly
Old Sep 6, 2015 | 04:09 PM
Barlow8869's Avatar
where you at in illinois ... let me guess ... lust outside chi town ... lol
Old Sep 6, 2015 | 04:15 PM
Engine: 5.0 305 tpi
yes lol Ive never really had alot of tbi issues.i have 3 tbi vehicle. When I first bought this car last month the throttle wasn't so hard. I replaced all the tbi gaskets upon when i first purchased it. 25 Dollars for the kit.I call it preventative maintence. I went out to the car 10 mins ago. It makes a squeaky noise when lightly giving it throttle with engine off.Everything moves freel. Im assuming something just needs to be lubbed up or greased. Its toilet bowl injection its not rocket science lol I could take a video if you really want to see this or hear it lol
Old Sep 7, 2015 | 11:53 AM
morgsie's Avatar
Could be the throttle blade contacting the side of the bore. Had this happen on my rather high mileage Caprice, throttle shafts were worn.
Old Sep 7, 2015 | 05:06 PM
Schurkey's Avatar
So what happened when you sprayed throttle-body (or carburetor) cleaning solvent into the throttle bores, and onto the throttle shaft?
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
kyleb24
Aug 15, 2015 08:24 AM
Randomtask2
Aug 13, 2015 01:57 AM
