Widest Tires?
Old Jan 28, 2001 | 01:19 AM
Ovrclck350's Avatar
Widest Tires?
Ok, so stock is 215/65/15. What is the WIDEST tires I can put on while retaining stock heighth? BTW, here's the rims I have.
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
92 Camaro RS 305 TPI
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
[This message has been edited by Ovrclck350 (edited January 28, 2001).]
Old Jan 28, 2001 | 03:03 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I've got 295/50R15, and they fit just fine. My rims are off of a '79-'81 turbo firebirds.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 28, 2001 | 10:47 AM
82camaro's Avatar
Car: 82 camaro SC
I think the 295's are too wide for the stock 7 inch wide wheels. The sidewall becomes distorted. 235/60's or 245/60's look good in my opinion.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jan 28, 2001 | 06:33 PM
GMI FAST's Avatar
I am running P275/35ZR18 tires on an 18X9.5 wheel. Same height. Just about 25.7 inches...
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 406" Bow-Tie NASCAR Tall-Deck, Accel Pro-Ram, DFI, AFR heads, HRC T76 Turbo, NOS 150-hp dry kit, TH400 w/GV overdrive, 12-bolt w/3.70 gears, 8-pt. S&W rollbar, Spohn suspension, 18" wheels, Baer brakes
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Old Jan 30, 2001 | 06:51 AM
Tom Batts's Avatar
Old Jan 30, 2001 | 05:42 PM
TransAm86's Avatar
I have "317"'s on an 7 inch rim
[This message has been edited by TransAm86 (edited January 30, 2001).]
Old Feb 19, 2001 | 10:21 PM
RICHRAD's Avatar
The best thing you can do to get the most from that rim is to go with a 225/60/15. Just slightly under stock diameter and giving you just a hair more punch. I hate to say it , but the stang boys learned it first in stock gt/lx 5.0s. G.M. wouldn't copy for their lives so they looked into 16"ers.
Old Feb 19, 2001 | 11:33 PM
RARE-ROC-Z's Avatar
actually i have the stock camaro rims 15x7's aluminums on my daily driver S10 and i run 235/60/15s and it fits perfect. i love these rims and tires. but i cant wait to run a set of IROC rims on my S10. it will look so mean having that 2.5L under the hood. awesome huh? but go with the 235/60/15 you wont regret it as long as you get some good tires, no cheappies..
1990 IROC-Z L98 350 TPI
AFPR 49PSI, GUTTED AIR BOXES, K&N, RAM AIR, UNDERDRIVE PULLEYS, PORTED PLENUM, B&M SHIFTER, 3.23 LIMITED SLIP, DUAL CATS, STOCK SUPER TURBO EXHAUST, COOPER COBRA XST's
ALUMINUM DRIVESHAFT OFF A 98 Z IN GARAGE READY TO GO ON. ALSO MAGANFLOW MUFFLER READY FOR INSTALL
MUSTANGS...ONLY 4 LUGS....HAHA THAT IS HILARIOUS.
Old Feb 24, 2001 | 04:50 PM
SlowCamaro88SC's Avatar
but the handling difference from going from a 15" to a 16" is amazing. I went from 235/60/SR15's on BF Goodrich radial t/a's to 245/50/vR16's on Firestone tires (top of the line, don't remember name) and Pirreli P7000's on the front. what a world of difference.
Old Feb 25, 2001 | 09:04 PM
kamac's Avatar
Car: 1989 Firebird
Engine: 2.8 MPFI
265/50-15 works just fine, same height as the 235's. BFG and Dunlop make them, about 80$ a piece.
Old Mar 14, 2001 | 10:36 AM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
I have the same 15x7 rims on my firebird. My buddy has 255 60 on 15x7 " rims on the back. They fit really well but I am not sure that our back spacing is the same. He has 235 60 on front. I think I might try 275 50's rear and 245 50's front. Does anybody know for sure what is the largest tires that will fit on the stock rims?
Old Mar 14, 2001 | 07:24 PM
RICHRAD's Avatar
Don't go with anything more than a 235/60/15 or 245/50/15 all the way around on a 15 x 7. 245/ 60/15s will rub on the front and 265/50/15s look distorted on that wheel size.
Old Mar 15, 2001 | 12:47 AM
Ovrclck350's Avatar
I went w/ 235/60's. Man, who brought this post back from the dead????
Old Mar 15, 2001 | 03:14 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I have 285X40x17 on all 4 corners on 17 x 9 SS wheels.
Go to the LATEST PHOTOS page on my site: at
http://www.lbsz28blown.cz28.com
Louis
Convertable
92 Z28 305tpi Auto
1/4 at 13.23 @ 106.1mph w/Paxton 10psi, Ram air mod,Water methanol inj.,52mm T/B,ASM Large tube runners, ported upper & lower intakes,AFPR,23# injectors,1.6 roller rockers,slp tri-y headers,3in. cat,3in. gale banks cat back system,3.42 gears,17x9 camaro SS wheels, 285x40x17 tires,and much more.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
