GTO headlight and taillight cover questions.
Old Mar 18, 2001 | 06:48 PM
Dan87IROC-Z's Avatar
I was looking at these in Jegs, they look pretty nice. Do they just snap in? Do the head light ones sit flush with the body? Do the head light ones impair your lights at night? Thanks a lot!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 18, 2001 | 09:42 PM
89 Iroc's Avatar
I dont have them on my Iroc but alot of my friends have them and yes they do dim your head lights a little but you could just take them off at night. Besides with the headlights on they do little for appearance anyway.
Old Mar 18, 2001 | 10:07 PM
eastbayrallysport's Avatar
i have them on front and back, they fit almost perfectly fluch and attach with 3m 2-way tape that is pretty damn tough, they include screws for added hold if you want. as far as dimming the lights, i just bought the brilliant white lamps and you cannot really tell the difference at night, they look very clean!
1991 Camaro RS, Teal w/ black interior, 3.1L V6, Accel tune up components, Speed Density air box with ram air and k&n filters, B&M console Megashifter with custom console cover plate, all stock audio replaced with pioneer equipment. 1985 IROC's with 245/50/16 Firehawks. Headlight and Tailight Blackouts
Old Mar 19, 2001 | 10:25 AM
WS - 666's Avatar
Blackouts = YUK. And the company is GTS.
If you do get the blackouts, be sure to take the "GTS" sticker off with a blowdryer and a razorblade or something, they look even dumber with the stickers still on.
Old Mar 19, 2001 | 03:53 PM
Jims83TA's Avatar
I have a Trans am. I saw the GTS black out covers, but they were made for Firebirds and Formulas and specifically said EXCEPT TRANS AM. I have lights from an '88 TA on my '83. Does anybody know why the GTS light will only fit on the firebird and formula and not the TA? I always thought the tail lights were the same. Also, how does that black out spray work? I saw it advertised, but wasnt sure if it would look ghetto and not last too long. I want to make my tail lights on my TA a solid black, instead of the grid style.
Old Mar 19, 2001 | 10:17 PM
johnyIROC's Avatar
I have purchased 3 sets of front blackouts now, and 2 different makes. Every time I get over 180KPH they start to lift up, and about two seconds later they are gone. I lost one set at the track, and the other two on the high-way..... can someone please tell me how to make these things stay on? An 18 wheeler almost put himself in the ditch because one of my covers blew infront of his window.
Old Mar 20, 2001 | 12:55 AM
FTC's Avatar
FTC
they do dim the lights a lot. i always have my foglights on at night or i cant see well. make sure you take the sticker off. they look 100% better w/o the GTS logo. ive lost two sets in the front also. one by hitting a deer, the other flew off on the freeway at around 130 mph or so. my most recent set havent blown off yet because i made sure to set them inside the light basket at a steeper angle so the wind pushes them down instead of lift them up. this set has taken the abuse of 145mph runs on the freeway and havent blown off.
Old Mar 20, 2001 | 01:53 AM
Z28Maniac's Avatar
I had one thatblew off on the freeway 'cause the cheap plastic bracket holding it broke! If I ever get another set, I'm gonna make a metal bracket and bolt them on!
'68 Camaro - Vortec 350
'91 Camaro RS - 305 TBI
Old Mar 20, 2001 | 02:31 AM
ONEFINE8T9's Avatar
well i know its not an iroc but if it helps i have them on the back of my firebird. Check sig for pic, i took the GTS stickers off. I hate those. I think the reason they dont have them for the trans ams is becouse they have that checkered design and thats dark as it is. Blackouts might be to dark before its dangerous.
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Mar 21, 2001 | 07:59 PM
Jims83TA's Avatar
So do you think they wouldnt be a good idea to put on my daily driver? I like the way the lights look totally black. I bought the '88 style grid lights for my '83 because of the fact that I couldnt stand the stock ones with those ugly louvers from '83. I want to see how bad the lights would dim with the blackouts on my car.
Old Mar 22, 2001 | 12:46 AM
RenoLB8's Avatar
VHT NIGHTSHADES
Can't blow off, can't be stolen, nice and black during the day, perfectly visible at night. Would only look good on the taillights and sidemarkers though. I love the stuff.
-Reno
'88 Firebird LB8
"Cerberus"
-Supercharged Hybrid LB8/L32 Project-
"You think you're weak and maybe I'm the cure, but I've got 6 pistons in my engine, and I got one for ya...it's a long shot"
http://www.angelfire.com/il/Firebird28/index.html
Old Mar 22, 2001 | 02:05 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Im on my second set 1st set broke apart this set 1 got cracked the other one frekin blew off im just gonna try to get my $$$ back POS if you ask me i have a idea how they could make em it woud cost more $$$ but they woudnt have this problem make it so it actualy slides into the headlight area like it wough have top bottom sides and the front all behin held down buy adheasive tape. Oh whos the one who wanted a copy of my recipt??? email me
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
pimprs
Sep 10, 2015 03:34 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
