Just painted my car.. A few questions...
Old Aug 20, 2006 | 11:16 PM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
I just painted my car today and I had a few questions. I painted it with a single stage paint and no clear coat. I had a few minor runs and i'm going to use the razorblade/1000 grit sandpaper technique to get them out. Is it ok to sand on the paint a day after it has been painted and I also need to know about buffing the car. What kind of buffing compound should I use? I heard not to use any kind of wax or anything until about 3-6 weeks after it has been painted is this true? Thanks for any information!
- Charlie.
Old Aug 27, 2006 | 08:08 AM
TheMutt's Avatar
Go to the local auto paint supply and get 3m products, perfect it compound and machine glaze ftw.
And I usually don't recommend wax for a few months to be on the safe side. Until the paint is fully cured because wax will seal it and your paint job will start to come up.
also, if you want to make sure you don't sandthrough, you can spend a couple of bucks and buy the small hard blocks that you can actually sand with. A little smaller so you can focus on the run and not so much the area around the run.
Old Aug 27, 2006 | 10:00 AM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
why no clear??? yea get 3M stuff, thats all i have used and it works almost without flaw.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
