Best time of year to paint?
Old Mar 29, 2001 | 05:58 PM
RenoLB8's Avatar
Does temperature effect how well the paint cures in the end? I'm just wondering because with all the new body parts coming this summer, should I paint it in the fall, or would winter weathe rbe bad for it and just wait until the spring?
-Reno
'88 Firebird LB8
"Cerberus"
-Supercharged Hybrid LB8/L32 Project-
"You think you're weak and maybe I'm the cure, but I've got 6 pistons in my engine, and I got one for ya...it's a long shot"
http://www.angelfire.com/il/Firebird28/index.html
Old Mar 29, 2001 | 07:09 PM
82Trans Man's Avatar
To the best of my knowledge the only difference in how the paint cures durring different times of the year is the temperature. For the catalized products you will need one that is a faster drying catalist. If done in cold temperatures you should try to keep the car warm for a few hours after painting (70 degrees is what Du Pont and Sherwin Williams recomend I think and it is a good rule of thumb anyways). Hope this helps.
Old Mar 29, 2001 | 07:56 PM
Happy17yearold's Avatar
My dad paints cars for a living and to answer you question it does affect the piant.The problem with painting in winter is that the paint takes longer to dry between passes so you have the chance of making the paint look like it spilled(i forgot the word).Also the winter might take the shine away because of the long cure time.It is also bad to paint during the the raining season because the humidity may be too high but that usally doesnt affect the car if it is painted in a booth.I suggest you paint the car over the summer of start of fall.If you do paint during winter you can buy a fast reducer which makes the paint dry faster or there is a product call rocket that has the same effect on the paint.
1988 Trans am.......best 600 bucks ive ever spent...305 5.0 but will save my lunch money and every penny to swap for a 350 tpi in the coming two years
Old Mar 29, 2001 | 10:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Slower drying won't cause a car to dull. Actually, just the opposite is true. The slower it dries, the smoother it is. That being said, it's still preferrable to keep the car warm. If it takes too long to cure, you run the risk of marking it up when you reassemble it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 29, 2001 | 11:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you're a poor a$$ & don't have a booth (like me),, (in cold weather) the longer time for paint (mainly clear coat) to dry,, makes it more prone to crap drying into the paint and runs/sags if you put it on just a pinch to thick.
while this may look good in a pic,, the dirt thatgot into it while curing,,,well,,, lets just says it's being redone
Another thing about temp,, (more so with urethane clear) it's prone to chip easier if it's not dried at an adequit temp
A few people I know that don't have a booth set up or can't contol the temp,, paint with enamel (like macco uses) and then wait for more favourable temps to color sand & clear with a good urethane clear,, it makes for an excellent low budget paint job that last
Example
Spring is not a good time to paint because of the pollen in the air. The only bad thing about rainy days to paint is that the humidity can cause the paint to has over (because of moisture) but,, with rain come little dirt in the air
The besst time IMO, for one to paint at home w/no sort of control over the surroundings wold be starting into fall. The temp is usually favourable & pollen is at its lowest since everything is ready to die for the winter. Just my .02,,, not that it matters
My Firebird It Lives Again!!(Sorta)
Your Car Here?
Part Diagrams
-It's always the last one
[This message has been edited by deadbird (edited March 29, 2001).]
Old Mar 30, 2001 | 02:38 AM
RenoLB8's Avatar
I'm not doing it myself, I'm thinking of possibly Maaco again (just shelling out for a REALLY good job), or some custom shop. Looks like I'll hold off on the wheels and do the paint this fall though. Thanks fopr the advice guys!!!
-Reno
'88 Firebird LB8
"Cerberus"
"Got a green light, got a red light, no cop, no stop, man I don't care, every one of you could be the same, every one of you could play this game, got a green light, got a green light but you're going nowhere..."
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
