17 x 9.5 "
Old Mar 27, 2001 | 10:39 AM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
17 x 9.5 "
is it possible to fit 17 x 9.5" zr-1 wheels on my 92 r.s. without rubbing. if so what tire size is good. thanks
twells
Old Mar 27, 2001 | 01:10 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Yes.
275 40 ZR17
You need Spacers.
Do a search of past posts. This topic has probably been covered more times than I have spanked Mustangs.
Welcome aboard.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Mar 27, 2001 | 05:57 PM
HybridZ's Avatar
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
You will need 2 1/4 inch front spacers and
1 1/4 inch rear spacers. I got mine from VetteBrakes but you can also get them from Andris Skulte. Skulte charges less for the same thing, go with him.
Have fun
http://www.91HybridZ28.homestead.com/91HybridZ.html
SS 17x9.5 wheels,
HOTCHKIS 1"drop springs,
HOTCHKIS tower brace,
Bilstein struts and shocks,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
SLP intake runner (plennum not ported yet, soon)
High flow cats,
SPOHN panhard bar, lower control arms, and subframe connectors,
Baer front track system,
3" Flowmaster Exhaust System,
2100 Stall High Performance Torque Converter,
300 watt sound system,
and soon to come...ZZ4 crate motor...hopefully.
Old Mar 30, 2001 | 07:46 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Heh,
I have a set of brand-spankin' new 275-40-ZR17's laying on the back of the Trans Am right now (on top of the car cover).
I also have a set of ROH ZS 17 x 9.5 inch wheels coming from Andris Skulte! It turns out that ROH now makes a wheel in the proper offset for third-gens that doesnt require spacers.
Life is good.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Mar 30, 2001 | 08:31 PM
rwendt's Avatar
Car: 1991 Camaro Z-28
Transmission: 5 Speed Manual
HybridZ. Beautiful 91 Z28. Is it Ultra Metallic Blue? I have a 91 Z28, same color, stock, 305 and 5 speed manual. My question is where can I get some touch up paint? 1 inch drop with the 17 in rims look really great. What type of wheels do you have?
  • 1991 Z28
  • Ultra Metallic Blue
  • 305 TPI
  • 5 Spd Manual
  • 3:08 rear axle
members.fbody.com/rwendt/
[This message has been edited by rwendt (edited March 30, 2001).]
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Numbah-1
Sep 12, 2015 08:57 PM
BuckeyeROC
Jul 13, 2001 07:50 PM
z28cam100
Jun 14, 2001 01:00 PM
MrZ28
Feb 1, 2001 02:37 AM
