Help cleaning motor
Old Sep 14, 2006 | 12:12 PM
RedL98's Avatar
Help cleaning motor
So I want to clean my motor. I've done it before but just certain spots. This time I wanna get everything clean with a hose. Is simple green good to use and what will I need to cover?
Old Sep 14, 2006 | 04:45 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
nothing really unless you have a cold air intake. and if your using a pressure washer dont point it at the gaskets at any type of close range. oh and if it doesnt start after you wash it, let it dry and it will start... lol. used to happen once at a dealership i worked at . but other then that we never covered anything up and never had any real problems. make sure you spray from the bottem too! make it purdy!
Old Sep 14, 2006 | 05:26 PM
RedL98's Avatar
Thanks. So is simple green good to use or should I go withsomething like Meguiars all purpose cleaner. Should I cover the fuel injectors and spark plugs?
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
