Custom color paint in spray cans???
Old Oct 10, 2006 | 05:05 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Does anyone know where I can get custom color paint in spray cans? My door sills have some discoloration and since they're not in a super noticeable spot I was considering giving them a good spray paint job. Problem is that although they're not in a super noticeable spot, I still want the paint to match as closely as possible to the original color so there's not a major color mismatch between the sills and the adjoining pieces. Are auto parts stores with paint shops able to put paint into the spray cans?? If so, I can just take my sill down and have a match done.
Any help or suggestions with this would be greatly appreciated!
TIA!
Old Oct 10, 2006 | 06:48 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Im pretty sure you can. Have you tried calling any paint stores?
Kush Paint Co.
Roseville, Michigan
Tel#: 586-293-4545 Fax#: 586-415-8415
Call them, they would be the type of paint store to be able to do it if any.
Old Oct 10, 2006 | 07:25 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Look for colorite,they make oem paint for alot of cars/bikes etc.
Old Oct 10, 2006 | 07:44 PM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
Colorite is the way to go!!!!
Old Oct 10, 2006 | 09:10 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
for the same price as getting a custom color in a rattle can, im sure you can get a gravity feed hvlp gun off ebay (if you have an air compressor).
Old Oct 11, 2006 | 02:26 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I have had good luck with paintscratch.com If you have the paint code for your car, they can exact match it in a spray can.
Old Oct 12, 2006 | 05:11 PM
I have the original RPO sheet in the back "glove box". I know it has the body color paint code but does anyone know if the RPO sheet as the grey trim color code??
Frozer!!!
Jan 19, 2024 04:55 PM
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
