Is it possible to convert car to removable hard top? w/in
Old Apr 5, 2001 | 11:02 AM
Superblue87Formula's Avatar
I was thinking that it wouldn't be too difficult to remove the section of the roof between the A and B pillars and put seals there so it could be removed. You could put short pins in the front and two locking handles on the back to hold it in place. On a car with subframe connectors it would still be pretty solid as well. I don't generally leave my car out in bad weather so a tiny leak wouldn't be a huge problem. Where would I be able to get some weather stripping in long lenghts like that that would seal it up well? Are there any other things to consider or problems I may run into?
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
Old Apr 5, 2001 | 03:42 PM
Jza's Avatar
Jza
I've seen it done on a white 92 Z28. It looked good with the top off, but the top was made of canvas and looked like crap IMO.
I've cut the center strip off of an 85 T-top car. It's a pretty clean cut. The extra metal from the strip could easily clean up as they looked only to be tacked on. You'd have to move wiring around.
I think if it was done well and used a painted fiberglass or smoked Lexan top instead of cheezy canvas it would be pretty nice.
Definitely would look at chassis stiffening. I would like to see one done well. Maybe even with T-top pins in the back and the same quarter-turn latches used in convertables in the front.
Old Apr 5, 2001 | 07:06 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
I thought about doing that a long time ago, but people gave me a lot of reasons not to do it... If you do it, more power to ya!! Id love to see pics of it done in real life.. Photoshop doesnt look real enough...
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Apr 5, 2001 | 08:27 PM
jm91rs's Avatar
"Greater Cincinnati F-body association"???? Tell me more
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon......"Custom" non-red material.
Old Apr 6, 2001 | 07:33 AM
jm, GCFBA is a loose group of f-body owners of all generations from around cincinnati, we have almost 100 members now. We have a message board and get together at the dragstrip, cruise-in's, etc.. Click the link in my sig to check it out.
As far as the top goes, I was going to re-use the piece of metal I cut out of the roof, that way it would look like a hard top (except for the seams) until I pulled it off!
Old Apr 6, 2001 | 05:37 PM
Matt86Z's Avatar
Watch A&E for Simon&Simon. The show was out in 1982 when the thirdgen came out. The car they use on the show has this very thing done to it. Check around for S&S fan sites, and see where they lead you...
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
