will these wheels fit???? could some1 please help me
Old Apr 6, 2001 | 01:23 PM
88ta_stangkilla's Avatar
http://www.salesco.com/wheels/eagle/series_077.htm i want to put the 17x8 on my 88 trans am will they fit???
Old Apr 6, 2001 | 01:26 PM
dallasiroc's Avatar
Should fit.
Get no more then a 5.5" backspacing.
Old Apr 6, 2001 | 05:53 PM
Ben87GTA's Avatar
More than likely those wheels won't work. look at the design of them.. its made for about a 0 offset, while your car needs about a 5.5" offset. not sure if eagle can custom that, but give them a call (I inquired about those 77's about 7 months ago, and they didn't have any to fit a thirdgen.) worth a shot though.
-Ben
Old Apr 6, 2001 | 11:35 PM
GMI FAST's Avatar
You are mistaken. 0-offset on an 8" wide wheel is 4" of backspacing. You are confusing the terms. 17X8 wheels will work with a 4" or 4.5" backspace...
1989 T/A, 400" CNC Bow-Tie tall-deck, JE 8.5:1 pistons, Scat H-beam 6" rods, Scat 4340 crank, Crower roller cam, AFR heads, Tiffin Racing sheetmetal intake, Holley 75mm t/b, DFI, variable injector controller, 72# inj., S/X fuel system, Hahn Racecraft T76 single turbosystem, NOS 150-hp dry fogger, TH400 w/GV overdrive, Dana 44 w/3.70's, Baer Track brakes, Simmons FR 18X9 and 18X10 wheels, P265 and P285/35ZR18 Nittos, Spohn suspension, Eibach Pro-Kit springs, KYB AGX shocks/struts, Corbeau Targa RS seats, TeamTech 5-point harnesses, Sparco steering wheel, MacEwen white gauge overlays, Phantom gauges/tach, B&M Pro Stick w/carbon-fiber ****, REAL carbon-fiber dash/console kit (don't ask), S&W 8-point rollbar, Lonza aluminum pedal covers, Pioneer/Boston Acoustics stereo system, filled side markers, Audi clear fender marker lights, custom clear front turn signals, custom clear taillights, IMSA-style cowl hood (don't ask), custom medium Intense Blue pearl paint, tinted glass. Whew!
Best ET w/383" S-trim: 10.796 @ 125.8 mph
Best ET w/400" turbo, nitrous: Summer 2001
Member of Midwest F-Body Association www.mfba.org
Old Apr 7, 2001 | 01:46 AM
nFORM91's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GMI FAST:
...0-offset on an 8" wide wheel is 4" of backspacing.</font>
GMI Fast is correct. 15, 16, or 17x8" rims as long as they are 0 offset and 8" wide will work on ANY 3rd gen F-body car!
This is a simple concept to understand. 88ta... or anybody else for that matter, for the record...
Don't ever let ANY tire shop jacka$$, or anyone else talk you out of getting the rims you want for your car! Chances are that they don't even know what the hell they're talking about! Just make damn sure you KNOW two things:
1) 3rd gen F-bodies were designed to fit 16x8" rims with a 0 offset for the FRONTS and 16mm positive offset (just under an inch) for the REARS. O offset on all four wheels will work but, your rears will protrude alittle!
2) You must be consious of your tire size and have the appropriate tires for the size of rims that you're buying. I've included (2) tire size calculator (links) for everybody to check out.
http://www.privatei.com/staff/kwenzel/tire_size.html
http://www.dsm.org/tools/tiresize.html
Also, Here's a site to help in understanding offset and wheel backspacing.
http://www.fikse.com/cad.html
know that backspacing is measured from where the HUB and wheel meet to the INSIDE EDGE of the wheel. So knowing your STOCK WHEEL SPECS, you should know your limits. Remember, as GMI stated, 0-offset on an 8" wide wheel is 4" of backspacing.
Did you know that an 8" wide wheel is actually 9 inches in total width? So now you know to also watch your overall width. Good luck all! I hope this helped.
nFORM91
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
