leds
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
leds
ive got ten 194 led bulbs and i got them for the gaugse then i realized hey those 194 in there are stuck in the socket after i broke one. so now i have a bunch of bulbs that i decided not to put in the socket. Well anyway i was wonderingwhat type of bulb is the license plate light, the brake light in the spoiler and the turn signals. I've already designated two to four of them to the headlight housing so when i finally get my clear headlight covers they will have a red glow to them with the headlights off.
if you've got any other advice for these bulbs that would look sick or any idea where to get the stupid translucent red bingo chips you used to use back in third grade cause i want to make my signal idicators red
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.sylvaniaperformanceshop.c...op/welcome.asp
JamesC
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If you switch to LEds in the turn signal they WONT blink.Something to do with not enough voltage being pulled by the LED to make the "flasher" engage(blink on/off).Also your underdash, Hvac,maplight (if you have them),shift indicator are 194 type.
Car: '83 Z28
LED's will work in the taillights and the front side markers. If you try to put them in the front directionals, you're gonna have problems. You can upgrade to a variable load flasher and they should work.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
