metallic engine paint
Old Nov 5, 2006 | 07:44 PM
white87iroc's Avatar
do you guys know of a metallic paint that can be used on engines and tpi units?
Old Nov 5, 2006 | 08:49 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
what ever it is, its going to have to be a high heat paint.
Old Nov 6, 2006 | 08:07 PM
rsmaroo92's Avatar
Car: 1992 RS T-Top
Engine: 305 TBI/ to be replaced w/383 forged stroker
Transmission: 700R4/ coming 200 4R
Not neccessarily, I've always used standard automotive enamel. I had an intake that my machinist couldn't get the paint off, no matter what he did, hot tank, etc.! It's basically baked enamel! I originally got the idea from an issue of hot rod tech tips.
Old Nov 9, 2006 | 05:57 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
How do you bake it, by using a torch and heating it up, or by letting engine heat curing it ?
Old Nov 13, 2006 | 06:57 PM
rsmaroo92's Avatar
Car: 1992 RS T-Top
No, the engine does it for you!
Old Nov 13, 2006 | 10:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
How hot do you think black paint on a car gets in the Arizona sun in the middle of a 100+º summer day ?
If your engine is getting hotter than that and blistering the paint off the block.. I believe the last worry you'll have on your mind is ruining the paint.
I know my back shop door painted w/rustoleum battle ship grey (lighter grey) in the middle of an So. IN summer (sun on it from 12pm to 6pm-ish) got close to 280º outside (steel door) w/o problems. That's just crappy oiled enamel put on w/no prep & a roller.
Use a descent (or even crappy) paint of your choice and you shouldn't have any problems.
JMO though..
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
