Anybody know anything about wet sanding?
Old Dec 6, 2006 | 08:33 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
The 15-year-old factory paint on my 92 had held up quite well, but I know it is not reaching its full potential. It doesn't warrant a new paint job AT ALL, but it is not as shiny as I would like for it to be.
Is it a good idea to wet sand and polish old factory paint? Would any harm come from it? And if it is OK, what steps would I take to achieve the best results?
Old Dec 6, 2006 | 03:56 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
what does the finish look like? Is it frosty....or does it just look dull? If it looks dull...I wouldn't wetsand it...I would just buff it first with some perfect it III and see what that brings. If the car has a frosty look.....it really doesn't matter what you do....clear doesn't last forever. good luck
Old Dec 6, 2006 | 05:47 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
pretty much what he said, i would jus hit it with some compound see what happens, start with a coarse one then use perfect it 2 or 3 then system one then glaze it, if that dont bring back the shine, its time for new paint.
Old Dec 6, 2006 | 05:50 PM
Bshaw's Avatar
wet sand tips
& if you wet sand use a really fine paper, & do not push hard!
Old Dec 6, 2006 | 06:13 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Your probably better off with a little compound as others have said, but is you want to wet sand use a 2000 grit and be carefull not to go too far. Wet sanding it will turn out better, but it's a lot more work and you run the risk of messing up the paint.
Old Dec 6, 2006 | 06:15 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I was always told NEVER to wet sand a factory paint job unless you're an experienced professional. The clear on factory paint is very thin.
Old Dec 9, 2006 | 08:28 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
it is thin
if you are going to wet sand it all you have to do is lightly scuff it with 2000
two back and forth movements is more than enough
hit all the side marker lights and taillights while you are at it
when using a rubbing compound set the buffer at the lowest speed
do small sections and stay away from the edges with the buffer and the sand paper
Hotrodboba400
Dec 10, 2019 07:07 PM
92-Formula
Dec 12, 2015 10:34 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
