weather strippin
Old Jan 4, 2007 | 11:23 AM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
weather strippin
how easy iis it to change your weather stripin.and what u have to take off to do it
Old Jan 4, 2007 | 01:06 PM
Gramps's Avatar
Car: 87 Camaro IROC
all you have to do is unscrew some screws at the ends of the stripping and start carefully peeling out of the grooves. each side is a 1-piece strip that goes up the A-pillar, around the one side of the T-top, and down the B-pillar (i call it the b-pillar, its the place right behind the door). start at one end and see what you need to unscrew, then continue carefully.
if your T-tops are leaking then mayb watch out because some other guy has put silicone in the grooves so itll be harder to remove. if your T-tops are leaking then you should go to this link and itll tell you how to fix that problem w/ about 2 tubes of silicone.
https://www.thirdgen.org/ttopleakfix
Gramps
Old Jan 4, 2007 | 10:30 PM
Car: 86' Z28 Camaro
i ment just the weather stripping on the doors buy the window
Old Jan 4, 2007 | 10:48 PM
Gramps's Avatar
Car: 87 Camaro IROC
oh i see. sorry for missinterpreting your question.
Old Jan 4, 2007 | 11:39 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Don't you love it when newbies either don't know how to use the search function or refuse to use it and ask a repeated vauge question and the next newbie to read the post gives info that doesn't make sense
Old Jan 5, 2007 | 12:05 AM
Gramps's Avatar
Car: 87 Camaro IROC
postwhore
your just mad cuz ur not from canada.
F-body-fan
May 4, 2026 09:42 AM
1MeanZ
Dec 18, 2015 05:39 AM
3.8TransAM
Oct 1, 2015 07:47 PM
Nick McCardle
Sep 10, 2015 08:36 PM
