ttop ques
Old Jan 30, 2007 | 09:15 AM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
ttop ques
would 92 camaro ttops fit on a 86 camar0
Old Jan 30, 2007 | 09:31 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Probably not. From what I've gathered, GM changed the small pin they used during 82-89 (they also used hooks for some years but I don't know which ones) in 1990 to a much larger pin. If you look at the pin you can easily tell that they're different sizes.
Old Jan 30, 2007 | 12:39 PM
Gramps's Avatar
Car: 87 Camaro IROC
if the pins are different sizes, then you just have to find a donor car with the larger pin recievers, they just bolt on the same as the small ones. but the T-top shapes are the same so thers no screwin up there
Old Jan 30, 2007 | 04:47 PM
Car: 2012 Corvette
Engine: LS3
When I was looking at t-tops with the small pin it looks like the weather stripping is different on the small pin ones. The plastic pieces that cover the pin recievers are different as well, not sure if that makes a difference though.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaysfs
Exterior Parts for Sale
Sep 18, 2015 11:59 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Victor6
Aug 30, 2015 02:09 AM
