Help with engine dress up
Old Mar 23, 2007 | 11:14 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I'm puting my engine back in the car in a couple weeks and am having a hard time deciding which valve covers to go with. I really like the fabricated covers like these. The AFR heads are machined for perimeter and centerbolt covers.
I think they will look awesome against the black block and aluminum HSR.
I think I'm gunna go with the fabricated covers but wanted some opinions.
Or I am thinking of going with these and painting the plenum with black crinkle paint except for the tops of the ribs on top(leaving those aluminum.
Old Mar 23, 2007 | 11:17 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Re: Help with engine dress up
I like the last ones with the black lines on them.
That would look absolutely sick with the TPI Plenum lines black with it..
Old Mar 23, 2007 | 11:22 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I know, that's what I'm thinking, and the HSR has the same lines.
Old Mar 24, 2007 | 12:02 AM
j dezzy's Avatar
Car: 87 TA
I've got the last set you've got shown. Except mine have the edelbrock logo in the fins on top. I'd choose those over the first sets you've got there.
Old Mar 24, 2007 | 12:51 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I had them with the logo on my 355 in my blazer and they were cool but I don't want he logo on these if I get'em. I think it cleans it up some without it.
Old Mar 24, 2007 | 01:12 AM
j dezzy's Avatar
Car: 87 TA
I agree, they look a lot better without the logo.
Old Mar 24, 2007 | 01:16 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
This is my favorite valve cover.
And in black crinkle
And since you've got a Pontiac
Old Mar 24, 2007 | 01:17 AM
Engine: 400
Here's the first one on my buddies motor. Those are AFR heads too
Old Mar 24, 2007 | 01:20 AM
j dezzy's Avatar
Car: 87 TA
I almost bought a set that say PONTIAC on them from summit. but instead of buying them and drilling out the holes I got a blank set with the holes already drilled and a local engraving shop is machining TRANS AM into them.
Old Mar 24, 2007 | 01:23 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
That's also a good idea. Buy blank aluminums and have Formula 355 or something machined in, hmmm.
Old Mar 24, 2007 | 01:30 AM
j dezzy's Avatar
Car: 87 TA
If you wanna go that route, a piece of advice would be to find an engraving shop...maybe a place that makes plaques or trophies. Most CNC shops won't do valve covers. I called about 12 or 13 different CNC joints and they all said no. I called 1 engraving shop, and they said "no problem, bring 'em in." They guy that's doing mine is even using the Pontiac font.
Old Mar 24, 2007 | 10:27 AM
Engine: 400
I just love the shape of the ones that say Chevrolet
Old Mar 24, 2007 | 12:39 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If you ever need anything CnCed get ahold of me. I could have done it for ya.
Go with some of these. I powdercoated em for a guy on here.
http://www.cecoatings.com/images/coa...s/DSC00703.JPG
Old Mar 25, 2007 | 11:49 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i vote for the no logo edelbrocks, i love the look of mine.
Old Mar 25, 2007 | 02:25 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I think this is what you are describing.
If I did it again i'd give the upper plenum a brushed aluminum look and go with the aluminum fabricated valve covers.
Old Mar 25, 2007 | 07:56 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yep, that's what I was thinking about. I can't tell in the pic but are the lines on top of the hsr aluminum? No offense, it looks good but I think I'm going with the fabricated covers and plain intake. I don't know if I like the plenum all black now that I see it.
Old Mar 25, 2007 | 09:18 PM
I don't like it either. I dont think I had the fins bare aluminum in that pic.
Looked beter kinda polished. Would have looked pimp with the fabricated valve covers.
Old Mar 25, 2007 | 09:53 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yeah, looks better with the fins bare/polished.
Old Mar 26, 2007 | 10:31 AM
BADNBLK's Avatar
COTM Editor
I attempted to use the fabricated v/c's on my car, and found that with the factory alternator mount on the drivers side the power stud on the alternator will hit the valve cover. You need the fabricated center bolts that have a recessed gasket rail instead of the kind that is straight up from the cylinder head... I hope you understand what I am trying to say. I have only seen one place that had this style, and can't remember who it was that was making them.
** I really like the fabbed v/c's better **
Old Mar 27, 2007 | 09:13 AM
Engine: 400
A set up without lines. I like it.
Old Mar 27, 2007 | 10:26 AM
BADNBLK's Avatar
COTM Editor
Code name - is this your engine?? If so did you weld up the fins in the plenum, then sand smooth? The aluminum log over the pass vc -does it serve a purpose, or just a neat way to route heater hoses? And most important - Where did you get those strut tower caps!!!
Old Mar 27, 2007 | 11:00 AM
Stephen's Avatar
Car: 87 GTA
The smooth plenum top appears to be a sheetmetal cover. With 90 degree bends on the sides, to fit under the runner bolt heads & enough length to fit under the plenum exttension mounting bolts/screws, to mount it.
I'm not liking the cover look. Maybe if the ribs on top of the plenum & extension were just filled, and then it all polished or painted. I'm just a fan of the stock ribbed look.
I wouldn't mind getting a set of those ribbed valve covers with the Edelbrock logo. Paint them and the plenum (maybe black? red?) and the have the rib tops polished, like mike1986fyrbird HSR intake pic on the floor.
Old Mar 27, 2007 | 11:30 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
YES ! Where did you get those strut caps?
Old Mar 27, 2007 | 05:44 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
This is my buddies car... everything is custom made by him.
His name here is 406TPI or something similar.
Old Mar 27, 2007 | 06:07 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
That, my friend, is not a cover. I machined off the ribs and hand made a plenum extension. Lot's of work went into that intake, wish I still had it...but we are on to bigger and better things. Also made the strut caps and the heater hose holder.
Old Mar 27, 2007 | 06:15 PM
Stephen's Avatar
Car: 87 GTA
Wow! Actual smoothed plenum. I'm betting CNC machined, to get it level, so it could be polished? I just assumed it to be a sheetmetal aluminum cover. That's a lot of work. If you were to go for the smooth look, that's the way to go!
Old Mar 27, 2007 | 07:40 PM
406TPI's Avatar
Car: 1985 IROC-Z
Nope, I set it up on a sine plate and machined it on a bridgeport.
Old Mar 27, 2007 | 08:30 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
ALways loved the look of 406TPIs plenum. I did the same to one and resold it.
I have one I cut the complete top out of. Then tig welded a nice piece of 6061 alum to it. Gonna polish it next. Give it a neat look with the tig wleded bead around the top.
Old Mar 27, 2007 | 09:45 PM
BADNBLK's Avatar
COTM Editor
406 - WOW!! That is some great work, but sorry to say that I will have to copy you in a similar fashion. I talked to friend that thought he could probably just tig weld the ribs in, then grind smooth on both the plenum and extension. Do you think that this could work??, or should I just plan on having it machined down?
Chris - you should see about making some billet strut caps
BADNBLK
Nov 16, 2016 09:12 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
