Engine bay painting...
Old Apr 23, 2001 | 06:34 PM
Reno's Avatar
I'm having the whole car done black (van nuys maui blue has gone to hell completely), and I was thinking of doing the bay white, just to make the enging more visible. Do I have to yank the engine for that, or can it be done in car? If I had it done proffessionally, how much do you think they'd charge? Thanks ahead.
-Reno
89 Formula
Old Apr 23, 2001 | 06:49 PM
Mach5's Avatar
Personally I wouldn't paint the engine bay white but that is my opinoin. It would give you the best results if you removed the enigine. This way you can get into all of the small spaces when cleaning and won't get any overspray on the block. While you have it out you can clean it up and paint it too. I don't think a shop would charge that much for it but if you do more prep work and just have them spray it then it will be a lot less.
Old Apr 23, 2001 | 08:53 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Trust me on this, you do not want a white engine bay unless you are addicted to cleaning and de-greasing. I have a white IROC and I am always cleaning under the hood.
I was thinking about going to flat black next time I had the motor out.
Old Apr 23, 2001 | 09:05 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Interesting, getting ready myself to paint my engine compartment and just for the hell of it I asked the Body shop that will be doing my car later how much they would charge for painting the engine compartment. $450 was the quote, that's me taking EVERYTHING OUT, EVERYTHING OUT!! then towing the car up to the shop and letting them do the painting. So I opted for the POR-15 engine painting kit. I suck when it comes to spray paint. So I figure I will use POR and brush it.
Old Apr 23, 2001 | 10:13 PM
Reno's Avatar
What's POR-15?
-Reno
Old Apr 24, 2001 | 12:30 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's your lucky day,,, i can give you a visual
You'll have to look past the wheels,,, among other the nastiness
Taking everything out does help alot,, but can be done leaving the engine in (everything else still has to go though)
My Firebird It Lives Again!!(Sorta)
Your Car Here?
Part Diagrams
-It's always the last one
[This message has been edited by deadbird (edited April 23, 2001).]
Old Apr 24, 2001 | 01:12 AM
Reno's Avatar
Now THAT is what I'm talking about!!!! You look at this black beast, rolling thunder, open the hood and BAM! There's the engine, bright as day, here to say hello. Wonderful!!! Thanks deadbird! Any specific tips? It sounds like you did it yourself?
-Reno
Old Apr 24, 2001 | 01:32 AM
83T/A_Dave's Avatar
I'm sorry I have to voice my opinion, but... that looks like a black refrigerator. I think that a car should have the same color engine bay as the exterior, but thats just my thoughts. EVERYONE TO THEIR OWN.
Old Apr 24, 2001 | 08:07 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
Before... http://www.geocities.com/duffster_go.../Photo0351.jpg
During... http://www.geocities.com/duffster_go...n/Dcp_0409.jpg
After...
http://www.geocities.com/duffster_go...n/Dcp_0542.jpg
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Apr 24, 2001 | 09:29 PM
deadbird's Avatar
Engine: TPI 305/ v6
83T/A,,, you mean like this ?
I can't believe you called my baby a refrigerator j/k
Reno-
The biggest thing with changing underhood color is how long you can have downtime on your car. It's no easy task removing all the crap from under the hood. The best start is to have a clean engine bay which means degreasing. I've always used Power Clean to do the dirty work mixeed with a few other degreasers and a pressure wash. I didn't have alot of cleaning to do this time around since I already changed it from red to black a few years ago and I hate dirty engine bays (especially if you have to do work on the car). Getting the wiring out of the way isn't very easy either since it's everywhere. I ended up hiding all my wires & moving things around just because I hate seeing wires too. Certain things that you don't want to unhook (like a/c lines, you can wrap alum foil around or saran wrap,,, it's alot easier than trying to paper them off. Remove everything you can and clean remaining grease with a strong thinner (like acetone or laquer). Scuff down the old paint with a scotch brite pad and clean with a wax/grease prep,, apply some Bulldog adhesion promoter (just for giggles) and paint the color of your choice,,, I used Plastikote spray paint on mine since at the time when I did it I didn't have an air compressor. If you whan just white white,, use some krylon,,, it comes out to a pretty nice finish if you paint it ight.
That's pretty close to how I did mine,, while there are lots better ways & paints to paint your engine bay,,, for $10 worth of color matched spray bombs,, it was more worth it at the time for me to go the route I did. Someday I might redo it the 'correct' way
[This message has been edited by deadbird (edited April 24, 2001).]
Old Apr 25, 2001 | 07:15 AM
Chuck Everly's Avatar
I went with the retro look. I used satin black like the older GM muscle cars used.
88 IROC convertible
-=ICON Motorsports=-
Old Apr 25, 2001 | 03:41 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I too believe that the engine bay should be the same color as the car, look here at mine.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
