Painting steps????
Old Apr 1, 2007 | 11:37 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Painting steps????
starting to prep for paint. I have new seals for the t tops, a few cans of primer and some tape.... I'm unsure what color i want to go with, prob gonna keep her red. i assume i should put the seals in after i prime and paint the rails and roof? i was gonna use a case of cans to paint but thinking of getting a gun? any good guns out there you guys use for a decent price?
Old Apr 2, 2007 | 09:25 AM
rebel1222's Avatar
Car: Looking
Re: Painting steps????
Spend the extra $ and get a decent gun. A Sharp Colbalt is a decent gun for the price. I only use the can primer to cover metal to keep from rusting just until I can get it sanded down to metal and put some good primer on it. before the paint. Are you going to go with a base coat/clear coat? If so, then use a urethane primer/ hardener.
Old Apr 2, 2007 | 12:41 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
i was planning on just painting the primer with a few coats of red. what do you consider good primer?
Old Apr 2, 2007 | 12:47 PM
rebel1222's Avatar
Car: Looking
Are you planning on painting the whole car? If so, what klnd of paint do you plan on using? Many today use the 2 stage urethane. base coat /clear coat. If that's the case, then you'll need a urethane primer/hardnener.
If your not planning on painting the whole car anytime soon, and are just trying to stop the rust, until later on down the road then I guess using the spray can is better than just letting it rust away. In that case I guess the Rustolem is about the best to pick up.
Old Apr 2, 2007 | 12:55 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Don't use spray can primer, it is lacquer and shrinks a lot when it dries. Sanding scratches that don't show up at the time of painting will show up soon after. It is better than no primer but that's about it. Definitely do not paint a car with cans. Cans are soft, low grade paint that has no hardener and no UV resistance. It will chip easy and fade very quickly. Also there is no way to get uniform film thickness when you are applying paint in a 1-2" wide fan instead of an 8-10" fan. Plus the atomization and fan width change as you empty the can since the pressure slowly drops.
Rustoleum is fish oil based. If you ever spray real auto paint over it it will probably make a mess.
Old Apr 2, 2007 | 01:43 PM
rebel1222's Avatar
Car: Looking
Exactly, that is why you must sand all the can primer off before putting real primer on the car.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Chad Speier
Sep 24, 2015 12:32 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
