84 black paint
Old May 18, 2007 | 10:53 AM
84 Raven's Avatar
Car: 84 Camaro Z28
Engine: 305 H O
Transmission: 5 speed
84 black paint
Does anyone know of a good wax or polish to use on the original black paint on an 84? I've tried several products, but most of them leave swirls and marks. The paint is laquer, according to the cowl tag. Tx
Old May 18, 2007 | 10:36 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
Re: 84 black paint
have you tryed nu finish? i hate swirl marks and i think you get swirl marks when you use rough and dirty rags,
Old May 19, 2007 | 12:40 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: 84 black paint
Rubbing Compound -> Finishing Compound (For both I suggest Turtle wax, it's cheap, and good with highspeed buffer) and ofcourse, -> 3M Swirl remover. It works great, turns crappy paint into good paint.
Old May 19, 2007 | 02:49 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: 84 black paint
If you're applying waxes and getting swirl marks, it is not the wax. It is the applicator/towels you are using. If you only have light swirls on the car, do not use rubbing compound!
Old May 19, 2007 | 05:04 PM
nick418's Avatar
Engine: L98, Hemi 6.2
Re: 84 black paint
pics will be alot helpful! How bad is the marring/swirls? Turtle wax compound is awful. Anything TW is terrible. Get pics up like sun light shots/ under halogen lights so we can see. I assume its probably not in great shape due to age/and improper washin/detailing techniques.
Old May 19, 2007 | 07:08 PM
klez's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L Ported SLP Runners and Intake
Transmission: 700r4 w/ shift kit
Re: 84 black paint
how about that Liquid Ice stuff? has anyone tried it? ive heard good things about it but not from car guys live ourselves
Old May 19, 2007 | 08:03 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Re: 84 black paint
For a black car i like meguires 9 swirl remover 2.0 with a soft foam pad on the buffer. After the car is swirl and scratch free. Micro fiber towels to finish.
Old May 21, 2007 | 06:38 AM
84 Raven's Avatar
Car: 84 Camaro Z28
Engine: 305 H O
Re: 84 black paint
There are pics in my vbgarage. The car has only 7400 miles on it; the paint is in extremely great shape; it's just that I'm not happy with how it turns out when I wax it. Over the weekend, I washed it and just hit it with Meguiars qwik detailer. It seems to be the only thing that doesn't leave a haze or swirl marks.
Old May 21, 2007 | 12:53 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Re: 84 black paint
I'd bet you are either applying too much product, or again, are using towels/applicators that are causing your swirl marks. What exactly do you use when applying the wax and removing it?
Old May 21, 2007 | 06:05 PM
1badnhra's Avatar
Car: 86 Firebird
Engine: 355 vortec heads
Transmission: 700r4 Huges 2500 stall
Axle/Gears: 4:10
Re: 84 black paint
On my 2000 NHRA Edition Formula, which is black, I like the Wax Shop Super Glaze. It's the only thing I will use on a dark car.
Old May 21, 2007 | 08:07 PM
nick418's Avatar
Re: 84 black paint
Buy MF towels from Pakshak, Autogeek.. Those are the best MF you can get, they are from Korea, not like the ones you get from Walmart. Swirl Marks come from people washing it improperly, wiping/dusting it... Im such a fussy person and see swirls on brand new cars in the showroom From dealers using brooms and dirty old rags and dusting it... On a 20 yr old black car you will expect swirls in it (even low mile cars).. Most people do not have good understandings on how to detail a car properly. Those pics still dont do justice, on how bad swirls the swirls are... You need the sun hitting directly on the paint, or have it under strong lights.. However, the paint looks very wet from far away.. We need to see those actual swirls your talking about. Theres many good companies like Optimum, Poorboys, Menzerna, Pinnacle Xmt and others that will take out most swirl marks/paint defects with a PC. Personally i love Menzerna IP with a white polishing pad and hit it with Menzerna Final Polish II (cant afford the PO106ff right now) These are abrasive polishes that will take out the swirls, not like many products that these car stores have that claim they get rid of swirls ( these are fillers that only hide the defects) I do a search on www.autopia.org. Great place to look thru. I was going through the same problems with my black 91 Z28 with 16k org miles.. By the way your car is really clean, awesome example of what a thirdgen should look like
Also i like to apply my sealants and waxes by PC (not hand) If you apply your LSP by hand, make sure you do it side by side, up and down motions... Do not do it in circle motions. This will most likely bring the swirls back in and makes things worst and harder for you.
Meguiars #9 is a okay product. Although it dust and doesn't have a good cut to it..
Old May 22, 2007 | 02:26 PM
84 Raven's Avatar
Car: 84 Camaro Z28
Engine: 305 H O
Re: 84 black paint
Thanks for your help and input! I appreciate it.
Old May 29, 2007 | 06:27 AM
84 Raven's Avatar
Car: 84 Camaro Z28
Engine: 305 H O
Re: 84 black paint
The Nu Finish did the trick! The car came out beautifully. Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
hectre13
Sep 8, 2015 03:38 PM
