side molding mod
side molding mod
I was thinking about doing the side molding mod and i had acouple questions
1.) Is it double sided tape like the 4th generation f-bodies
2.) What was everyone's experiences?
3.) What tips/techniques do you have
4.) Any pictures
4.) Any pictures
Car: 1992 Camaro RS
Axle/Gears: Stock
Re: side molding mod
Are you talking about removing the door molding? If so, then yes it is taped on. And you should try applying some sort of heat to loosen it up a bit.
Also, don't pull too hard/fast. The paint will come off with it.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Not all were double stick. The earlier ones 82-? You kno the thin black style, those I believe are riveted on. Also have any of the parts of your car where the molding are been repainted. If so they may have painted over the molding. Depending on the age of the paint you may notice a differene in color due to fading, especially red.
Matt
Matt
Its an 86 Z w/ original paint, the moldings are white as well, the main reason why i want to remove them is they are turning yellow in some spots and it looks bad. I think it would give the car a cleaner look as well, just worried about removing paint along w/ the molding
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Matt
Matt
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
My 89 Gta had the moldings removed. When I had my 85 z painted they replaced the molding and it was just double sided tape. I have been thinking of doing the same thing to the 85z.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
1992 Trans Am
May 10, 2023 07:19 PM
