Removing center console,and how to fix it
Old May 3, 2001 | 09:34 PM
Stormshadow GTA's Avatar
I want to remove it so i could glue that siding back on,you know that **** thta peels away.Any suggestions on how to fix it.First how do i remove the console.
Old May 3, 2001 | 09:41 PM
87bird
Guest
Posts: n/a
I glued mine back a while ago...you don't have to remove the console to do it (I didn't anyway...) I just glued it and used tape to keep it tight against the console over night while it dried.
Old May 3, 2001 | 09:56 PM
86ZRICHIE's Avatar
console is easy to remove, start with radio and shifter plates, then there are 1 or 2 bolts under the dash in on the side of the console, then the rest of the bolts are either under the shifter plate or in the glove compartment. You have to remove your stereo and HVAC controlif you need to take the console out of the car to work on it since they're attached to the top piece.
...D'oh, I just realized you have a 'bird not a 'maro, nevermind
Old May 4, 2001 | 01:52 AM
jobryan26's Avatar
What kind of glue did you use?
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
Member at kyfbodies.org
Old May 4, 2001 | 01:54 AM
camaro 22's Avatar
i used liquid nail.
Old May 4, 2001 | 10:52 AM
jobryan26's Avatar
Didn't that take forever to dry?
'87 Trans Am:
(Engine)
305 TPI
JET Fan Switch
TB Bypass
Accel Super Coil
(Stereo)
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
DonW
Aug 24, 2015 08:24 PM
Firebird sweden
Aug 16, 2015 05:02 PM
3rdgenparts
Aug 8, 2015 07:09 PM
