Scratched power bulge!!
Old May 9, 2001 | 02:18 PM
magnus's Avatar
Some envious person seems to have taken the liberty of scratching one of my power bulges (the passenger side one). The scratch doesn't seem to be too deep. I was wondering if maybe I could buff it out somehow? Is there some compound I should try?
The bulges are black.
Also, are they painted plastic? Or black plastic? That's my biggest fear.. buffing the paint right off.
Thanks.
Adam .R - 1992 25th Anniversary "Heritage" Camaro Z28 5.7L 350ci - SLP Intake Runners, SLP 58mm Throttle Body, SLP Catback Exhaust, SLP Crank Reduction Pulley, SLP Custom PROM Chip, SLP Shift Improvement Kit, SLP Flow-Booster Airfoil, SLP 160 Thermostat,GMC "Syclone" Fuel Pump (90psi), Accel Fuel Pressure Regulator (38psi), Richmond 4.10 Gears, BMR Lower Control Arms,
Old May 12, 2001 | 10:07 AM
magnus's Avatar
anyone?
Old May 12, 2001 | 04:12 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
i hope im not alone when i say what the hell is a power buldge? a wheel flare? if you had pic that would help.
Old May 12, 2001 | 08:17 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I'm pretty sure they are painted plastic like the ground effects. Check the tech articles, I think there is an article about paint repair.
[This message has been edited by 91DropTopTA (edited May 12, 2001).]
Old May 14, 2001 | 04:17 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Magnus
I think that there are different ones...Mine happen to be White.... but I have seen Black ones before
I think it all really depends on how deep the scratch is if it's as minor as you say I was able to get a couple of small ones out but they were pretty small
When you do buff them just go slow and take your time and don't press too hard
edit=Oh yes they are Plastic
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
[This message has been edited by Hecubus (edited May 14, 2001).]
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
