car cover and antenna??
Old Sep 11, 2007 | 07:19 PM
dukie's Avatar
When you are using a car cover what do you do with the antenna? Just leave it on and let it bend or does the cover have a place for it to go?
Thanks in advance
Old Sep 11, 2007 | 07:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: car cover and antenna??
Some covers have a hole for the antenna, but if not then the antenna can be removed pretty easily before covering the car. You could also use a grommet kit and put your own hole in a cover.
Old Sep 12, 2007 | 12:51 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I would just unscrew the antenna and throw it in the car.
Old Sep 12, 2007 | 03:19 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Old Sep 12, 2007 | 10:36 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
dunno if your camaro was set up like my bird but find yourself a pwr antenna and pop it in there. on my formula it was just a matter of running the harness thru the hole where the recept wire comes thru and buying a relay and all of this was plug and play.
there is a plug behind the panel that is above the hush panel on the pass side. screw the relay down with the exsisting screw boss thats behind this panel and plug both plugs in to the relay and your done. i had a similar issue with covering up my car and thats how i fixed it. the whole project takes about 45 mins.
Old Sep 12, 2007 | 10:42 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Originally Posted by 92RS(real slow)
thats what I do with my maro
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 01:18 AM
