tint removal
Old May 16, 2001 | 08:35 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
tint removal
Whats the easyist way to remove window tint from glass.Mines gettin pretty nasty and i dont really want to pay someone to do it for me......
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
AND IT HAS A NASTY BITE......
CNYFBA MEMBER
http://cnyfba.cz28.com/
Old May 17, 2001 | 02:28 PM
88 Camaro SC's Avatar
Car: 99 Trans Am
All I did was scrape as much off with a razor as possible, then used some started fluid to eat away at the glue to get off the rest.
Nate
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.comp
Old May 17, 2001 | 03:13 PM
Jza's Avatar
Jza
Use a razor to get up about an inch or so of the corner (enough to grab onto) then slowly peel it off by pulling it back. Pull slowly with even pressure on the whole piece. If it rips anywhere, start turning into the rip until it comes up without further ripping. With this technique, you can usually get the whole side window in two or three pieces. It's a hard technique to explain but it works really good, and even usually takes most of the glue with it. The trick is even pressure along the whole piece as you're peeling it off. You'll still have to attack some glue residue, though. Warm soapy water worked best out of the 15 or so chemicals I've tried.
Old May 17, 2001 | 04:17 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
1987 BLUE IROC
IT'S A DOG
BUT IT'S MY DOG
CNYFBA MEMBER
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Fronzizzle
Feb 9, 2017 09:31 AM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
