15x10 back spacing
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 15x10 back spacing
Typically 15 x 10 rims will use 5.5" of backspace on a third gen providing you're using a third gen diff. If you use a fourth gen diff, 7.5" backspace.
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
sorry not trying yo hijack but what kind of modifications is needed to fit this size wheel and also does anyone have any pics with this setup? if the wheel was bigger lets say a 16-17"x10 would the backspace still be the same?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
rim diameter will not change backspace, and since the side wall grows shorter on bigger wheels, clearance should remain the same. I have 15x10 with 5.5 backspace in my sig
Fronzizzle
Mar 18, 2019 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
