Question on "prepping" a car for a paint job
Old May 20, 2001 | 05:48 AM
GTA-Force's Avatar
What does "doing prep work" on a car before you take it in for a paint job mean, and what does it consist of?
Thanks!
Jason
1989 Trans Am GTA: 350 TPI, N10 Dual Exhaust
Mods: K&N, Dynomax Super Turbo muffler, 3.5" intermediate pipe, twin Dynomax Super converters, Dunlop Sport 4000 tires.
All of us have potential...few ever realize it.
Old May 20, 2001 | 10:39 AM
EVILFACE's Avatar
I basically sanded the entire car with 320 grit sandpaper. My car was pretty straight except for a few dings. It also good to remove the mirrors and the ground FX.
EVILFACE
88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element
Runs A Blistering 16.5 @ 81.5 mph (due to major tire spin)
http://www.evilface.com/evilscamaro.htm
Old May 20, 2001 | 10:59 AM
Tom Keliher's Avatar
I prepped my Formula 350 before I had it painted, and saved a ton of money on labor charges. I don't recommend you do any sanding. Leave that for the pro's at the body shop. What you can do though, to save lots of money is remove all sorts of things. Here is what I did:
Romoved all decals, using 3M decal and adhesive removers
Removed the turn signal lenses in front and the tail light housings in the rear
Removed the outside mirrors
Removed all the front underneath air dams and air deflectors
Removed the inner fender liners
Removed the rear spoiler
Removed the hood bulge scoop
Removed the side marker lights
This allowed them to mask and sand and paint the car for a lot less labor ($$$) and the paint job came out looking 100% better because there was no tape lines or overspray on all the parts I removed, and things like the mirrors and spoiler were painted seperately and then attached back later and looks just that much better.
There will be overspray everywhere else: under the car, up in the engine compartment, on chassis pieces. Be prepared for that and to do some overspray clean up when you get the car back. But the effort you put into it will make the paint job look that much better. The money you would have spent on labor, you can spend instead on better paint, clearcoat, and color sanding for that show car finish all for the price of a "regular" paint job.
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
