17" rims
Car: 1992 trans am tpi 350
Engine: tpi 350
17" rims
couldnt decide where to put this question, but how much of a difference does it make on the speedo when you switch from a 16" rim to a 17" rim?
Engine: tpi 350
Re: 17" rims
Not a problem :-)
http://www.miata.net/garage/tirecalc.html
You can use that to see the size differences in different tires.
Car: 87 GTA
Re: 17" rims
Look at the overall diameter of your stock 15" or 16" tires, then find a 17" tire that fits the new rim, but is as close as possible to the original tire.
Look on Tirerack.com, to compare sizes, and look into the +1/+2 selection.
Engine: tpi 350
Re: 17" rims
ok one more question, will these fit with the 245/45/r17
http://hawksthirdgenparts.com/index....ROD&ProdID=480
Engine: tpi 350
Car: 87 GTA
Re: 17" rims
245s were the stock width on the stock 16" x 8" rims. 255s fit quite nicely too. Which is the widest 16" street tire you can get, unless you jump to the 295/50s, which is the MAX or our 16" x 8".
Some people will tell you you can't do it, but I have before, a buddy has them now, and I'm only waiting for my current 245s to wear out.
Car: 1987 Firebird
Engine: 355
Re: 17" rims
the 245/45/17 and 275/40/17 combo is very popular. Its what im running, and they only vary .02 of an inch or something like that.
However, i think our cars are supposed to have 235/60/15 tires on. Not sure what the the height of that is, but if you look at the sticker in your door, it will tell you what you SHOULD be running, try to match it to that.
Re: 17" rims
https://www.thirdgen.org/1984-pontiac-firebird
They started using them back in 84
Engine: tpi 350
Re: 17" rims
That depends on the car. However, the cars that got the V rated 16 inch tires got a 245/50/R16.
Car: 1987 Firebird
Engine: 355
Re: 17" rims
ok, 245/50/16 is only off by 0.1" from 245/45/17 and 275/40/17.
The latter two, are almost identical. Off by about 0.02". So if u want to run those, its prolly ur best bet.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: 17" rims
I'm running 275/40/17s front and rear. I didn't notice any variation in the speedometer.
Car: Used to drive a camaro
Re: 17" rims
25.7" OD is I think the target rotating diameter. Less or more will scew with the speedo. I'm running 17's and the 245 front / 275 rear deal. ALOT of us do that. 18's are nice too but I can't bring myself to spend the money on the "correct" setup knowing 1 good New England pothole could cost me big money to fix.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 17" rims
25.7 is stock
AC,
i bet ive got bigger potholes down here
AC,
Re: 17" rims
86TA, true that...you have the potholes that result in a 12 second ETA to drive into and then out of....LOOOOONNNNGGGG potholes. I was in Ocean City last summer for a few days in the ol' minivan and I dropped into a few and was like "what the f was that"...only to say 4 seconds later "what the f was that" not realizing I was exiting the pot hole I'd hit 4 seconds eariler.
Car: v8 s10 and a stock 1989 firebird
Engine: s10 is 355 firebird is 305
Transmission: 700r4 full man valve body in s10
Axle/Gears: 3.55 in s10 2.73 in firebird
Re: 17" rims
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
