rim cleaning help
Old Feb 15, 2008 | 08:32 PM
Dave_Knight's Avatar
rim cleaning help
What is the best way to clean these rims? They don't feel/appear to be alumnum. Can anyone give me info on these beside the fact that they are 15in 5 lugs? Came from an 84 Trans Am.
Thanks for whatever info you can give me.
Old Feb 16, 2008 | 02:29 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: rim cleaning help
They are aluminum wheels, painted gold. Since they're gold, I'll assume the car is black with gold ground effects, that's the only color combo I've seen the painted gold wheels on. They're 15x7" wheels, and are the correct wheels for an 84 T/A. Those are pretty much the most common wheels on thirdgen firebirds, found on 84-92 cars. Firebirds and T/A's both got them. As far as cleaning them, soap and water will probably be your best bet, maybe simple green to get brake dust off. They can be refinished as well, by stripping the old paint off and repainting them. It does take a bit of effort though, getting the old paint off can take a while because of all the areas to get.
Old Feb 16, 2008 | 06:40 AM
Thanks for that info. The aluminum gold part I can clean I think, but what I'm having real trouble with is the thin circular strip of metal that seperates the gold aluminum from the tire rubber. This is starting to get dirty and slightly corroded. Would I just take a wirebrush to this part? Thanks.
Old Feb 16, 2008 | 10:53 AM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Sand paper. Lots and lots of sand paper. Then a polish of your choice. You can also paint the holes an accent color.
Here's mine after lots of sanding and polishing.
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
