Firebird Headlight problem
Old Apr 15, 2008 | 06:42 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Alright so I got the pop up headlights obviously and the motors have been replaced twice and it doesnt make a difference...still have to keep the lights up with zip ties....is there something else that could be wrong?
Old Apr 15, 2008 | 08:46 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Firebird Headlight problem
Check with a dealer or parts store. I think there is a relay on the firewall that controls the power to the motors.
Old Apr 16, 2008 | 02:27 PM
jstuart83's Avatar
heres how to check the relay turn on the head lights and see if the manual lift ***** are turnning if they are it is the plastic pieces in the drive assembly first are these used or rebulit motors, i assume you just swapted out the whole assembly when you replaced the motors did you open the gear drive assembly there is a large gear that runs on the worm gear of the motor inside of that large gear there is another plastic piece which is where the headlight raise and lower arm screws to. if you remove the plastic piece that fits inside of the plastic gear there are three plastic ***** that gm used to connect the two incase something went wrong the plastic ***** would break well after 10 or 15 years these things crumble, and the two are not connected anymore allowing the motor to turn but not raise the headlight, and if you can raise and lower them without turnning the manual lift **** they are not connected if the motors are bad and still connected to the raise and lower arm you could not raise or lower the light without turning the manual **** you can use 3 nuts i can't remember which size i used it was either 1/4 inch nut or a metric one take the assembly with you to the hard ware store when you go. pm me if you need more information i will try to find some pictures
Ghettobird52
Jul 5, 2024 11:18 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
