Hail damage
Old Jun 15, 2001 | 11:53 PM
THEISENATOR's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Hail damage
I just got some hail damage on my car, any suggestions?
91 Camaro RS
Red V8 coupe,
Ground effects,
Stingray "intake" on Hood,
Alum. Rims,
Sony Deck,
Rockford Fosgate punch 400 amp,
Two Rockford Fosgate 12 inch subs,
Tinted windows,
White face gauges,
GTR Carbon Fiber Rear Wing
Working on more mods for speed.
Old Jun 16, 2001 | 12:29 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
insurance?
91 Z28
Mods: SLP Exhaust, umm...nothing else..sorry
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Webpage coming soon.
Old Jun 16, 2001 | 10:32 AM
Car: 1986 Camaro
Engine: 383 Stroker
I don't have full coverage. It's only bad on the hood, everything else isn't as bad.
Old Jun 16, 2001 | 03:11 PM
Ions91Z28's Avatar
get you a cowl... and go on. Not much you can do. Hail is horrible stuff
Old Jun 17, 2001 | 11:57 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If you don't have a lot of dents you might consider one of the new "paintless dent removal services". Since hail many times doesn't chip the paint and really just stretches the metal, the paintless method has had good results shrinking the metal back into shape bypassing major repairs.
Old Jun 17, 2001 | 02:17 PM
Car: 1986 Camaro
Engine: 383 Stroker
That sounds like it will work, i will have to look into it.
Old Jun 17, 2001 | 02:35 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
When I bought my car I had some slight hail damage all over. Most of the spots were smaller than a dime, and because the car was yellow it did not show really bad.
To take care of the problem I got myself some glazing puddy, It is a fine grade bondo is all. I sanded the hood really well, only down to the primer (dont go thru the primer cause from the factory it is usually better than aftermarket primer. Since they bake it.) Of course that also depends on the year and where your car was made.
Do not try and sand out the dimples of the holes yet, only try and find them when you sand. What should happen is you will sand to the primer and everywhere there is a small dent you should leave paint color, and as ling as your car is not gray you should find amm of them.
I then took some Steel whool togive the bondo something to adhere to and then I began to fill. Sand with a coarse sandpaper and go finer. wET-SAND THE surface, wipe it dry and remove the sanding dust with a cleaner towel.
take water and smear it on evenly to make it shiney and look for the inperfections. Repete process untill you have a smooth hood.
Prime the hood, and wetsand, wipe it clean and then wipe more wather on the hood, look at the reflections again to see if you missed any small dents or for abnormalities. Repeat until you have a smooth hood.
Prime, and Paint. Its alotta work, took me a few days of messing around to get it perfect, Now the car looks better than it did off the line beause of all my work.
<img border="0" src="http://www.tir.com/~jazofko/images/Exterior/87Formula%20w%20black%20cowel%20Front.jpg" width="353" height="259"></p>
John
87 Formula 5.1 converted to TPI Yellow/Black
SLP Dur 206/212, Lift 480/487, Cent Line 112 cam, headers, cat-back exhaust
Ported & polished Stock TPI intake
Modified Stock cold air intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
88CamZ
Oct 8, 2015 10:29 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
