dirt stuck to 6 month paint
Old Apr 17, 2008 | 11:22 AM
blue iroc's Avatar
Car: 1989 iroc
Engine: 5.7 L98 tpi
Transmission: TH700-R4
Axle/Gears: 2.77
Greetings,
My 1989 iroc had a quater panel dent repaired about 6 months ago. It got a 2 stage paint job which looked really dull to begin with but with a buffing it came out looking really good. From the start dust seemed to be attracted more to that part than the rest of the car. About a week ago i washed the car again but the dirt wont come off. I mean it's really stuck to the car. What can I do to fix this?
Thanks,
Gerry
Old Apr 17, 2008 | 11:55 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: dirt stuck to 6 month paint
Light sand it and repaint. If it's stuck to the paint then it was there when they painted the car.
Old Apr 17, 2008 | 09:51 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Try to clay bar it.
Old Apr 17, 2008 | 10:13 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Before you do any kind of sanding, I would try a claybar first as stated above. Make sure to keep it well lubricated.
Old Apr 18, 2008 | 01:19 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Once you do get it off, put a good coat of sealer wax on the area. That will keep it from happening again.
I would try the following, in this order, until it's off (these are going from least to most abrasive, the idea is to remove as little paint as possible):
1. Claybar
2. Polishing compound
3. Rubbing/Buffing compound
4. Wet sanding with 1500 grit sandpaper (only as a last resort, it's easy to sand through the paint)
Old Apr 18, 2008 | 07:54 PM
Goonv8's Avatar
The problem is almost certainly that your clearcoat (and most likely, the base) has not been allowed to harden properly before the cutting process has begun. You can test this by just lightly scratching a low visability area with your fingernail. if it binds at all, then the laquer isn't hard. you say that it was dull to start with and that's a little worrying as even before cutting, clear should look fairly glossy. I bet that the base wasn't allowed to harden before the clear was applied. It will harden with time. I have the same problem with my yellow '83. If I looked closely at the paint, it had lots of black specs in it. Here in blighty, I used AutoGlym paint renovator as its not too abrasive. I've also used the Maguires three stage cut, polish and wax system and that worked well. Clay bars are good but the laquer must be hard before you use one as it will bunch up the paint if your not careful, especially on a respray.
Old Apr 18, 2008 | 08:31 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i agree, it almost seems like the paint job was rushed....i would be
Old Apr 19, 2008 | 08:55 AM
blue iroc's Avatar
Car: 1989 iroc
Engine: 5.7 L98 tpi
Axle/Gears: 2.77
Everybody who responded, thanks. I do really appreciate the help.
Hawk312
Aug 22, 2017 08:55 PM
Papaginos
Sep 27, 2015 03:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
JHX
Aug 29, 2015 02:30 PM
g.l.mos
Aug 22, 2015 12:02 AM
