Flaming Exhaust???
Flaming Exhaust???
I have a 91 Z28 and i saw a car with flaming exhaust. It looked bad *** . Anyone know how this is done?
91 camaro Z28:K&N's, flowmaster 3" cat-back exhaust, competition stero, strut tower brace, ZR1 chrome rims, eibach springs, slp headers, msd wires, bosch +4 plugs, throttle-body-bypass, kyb shocks-struts, airfoil
Car: 89 formula
Transmission: t5, soon to be t56
umm ok...ill take a crack at this question...you mean you want it to like shoot a flame out the back right?..(or out the tip..whatever)...ive seen it done at some car cruises and it looked like they put a spark plug type thing (anything that makes a spark and can be controlled works here i do belive) and drilled a hole to mount it in the tip of the exaust then run power to it from the battery or where ever else you might get it from...and put a switch in the car someplace...on the one i looked at the guy ran purge lines from a nos system right by the tip for a big old flame thrower type trick...not safe..but the car was a trailer baby so it didnt matter all that much...hope this helps
Snuffit
p.s. im almost 100% sure if you use that on the street with cops and such...you will get a very large nasty ticket...so play smart
Snuffit
Snuffit,
Thanks for your help. The spark plug thing is what i was told but i did not know if it would work. Would i have to use spark plug wires to run the charge to the plugs?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You'll need to run through a coil or a step up converter first. 12 volts won't have enough potential to spark the gap. You'll need 30k volts or more.
You'll also need an accelerant, which obviously is the unsafe part. If you kill yourself trying to route gas into your exhaust it's not my fault, but remember that you do have a high pressure fuel line nearby.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: 82 camaro SC
Fire near the gas tank, not on my car.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
My car pops flames out the exhaust. Not those big huge flames like in the movies. But when I'm revving kinda high for awhile and suddenly let off the gas a flame will pop off in my exhuast.
Chris
91 RS 305 TBI
Eternal Rev
Chris
91 RS 305 TBI
Eternal Rev
How did u get it to do that?
A friend of mine has got a flame throwin system on his '69 Charger he ran a ACCEL super coil to the back with a spark plug in each exhaust tip. I am not sure about all the details to it, though. You can use a accelerant like fuel or nitrous but this is highly unsafe. Just the exhaust is enough to create a flame about 2 ft. long. Also remember that the bumper covers on our cars are not metal so you would have to have longer tailpipes that would stick out past the bumper. If you don't the bumper cover and your paint will be toast. Good luck!
<font face="Verdana, Arial" size="2">Just the exhaust is enough to create a flame about 2 ft. long.</font>
If you do, just don't go crazy with it for any extended amount of time; e.i. long enough to heat up your fuel source which happens to be close by.
Car: 89 formula
Alrighty...i called up the guy who i remember having the flame thrower in his tail pipe...he says it needs the extra charge from the coil on the spark plug in the tail pipe to work...and he said it will work without gas or nos running out the back...but you really need to hammer it and then quickly let off to do it...and then its not all that great...for the movies effect he said if you didnt want a gas line running from your tank...and dont have nos...you would need to rig up a hair spray like can (i assume he means any flamable arosol can) with a line running from wherever the can was...with a pressure solinoid valve that you have control of in the car...then rig both the valve and the spark plug control to fire at the same time (well it would probably be smarter to let the valve go a second or so first...for more of a flash flame to start)... hope this helps...i think the guy knows what hes talking about...but like the others say dont melt your bumper...that would be bad...
Snuffit
Snuffit
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
just for you guys thinking you are gona spray nitrous out your tailpipes and light it up......Nitrous (N20 BTW) is Not Flammable. it will not ignite and you will not get a flame. just a little FYI.
Car: 1992 RS
Engine: 406 Stealth Ram
The hair spray can idea is pretty sweet. I bet it wouldnt be hard to do, either. Get a small solenoid valve (dont know where to get that), and rig up some small braided hose to your exhaust pipe. I bet 2 cans of cheap hair spray would last quite a while, too. I may just have to try this.
The flame thrower effect was real big in the 50's with the big Merc'lead sled crowd.
it was done with a spark plug mounted in the tailpipe drawing power from the coil, and the fuel system running in a rich condition.
There are still a few of the oldtimers around at cruise nights doing this, just like they did when they were part of the original craze.
'86 Camaro SC 2.8 V6, 5spd, T-Tops
Mods:
(Performance)
Flowmaster cat back exhaust
(Non-Performance)
Pioneer DEH-P4000 head unit
Pioneer 6X9 Tri-Ax speakers
Jensen 8" dual voice coil sub
Blacked out tail lights and side markers (VHT
Nightshades spray tint)
Mods:
(Performance)
(Non-Performance)
Car: 1992 RS
<font face="Verdana, Arial" size="2">Originally posted by One Eyed Jack:
Yeah you guys are sounding like riceboys now :P If you want flames just go find a kit. I'm sure they've got some out there. But anyway Ive heard propane works nice.</font>
Here is the simple meaning to rice!! :
Rice - Making cars fast, which are not made to be fast. Ex. Civic, damn it! cant even think right now, u know what i mean.
1992 z28 25th Anniversary
All black w/ z28 wing
Flowmaster Exhaust
350 TPI
Flowmaster Exhaust
350 TPI
Hey Scott, if you do anything that works, let us know!
actually there is a ***** kit to make flames shoot from the exhaust to make it look like you have a high hp turbo car. i don't have a link to it though, so i can't give you any more info.
<font face="Verdana, Arial" size="2">Originally posted by Amrish:
</font>
</font>
I'm doing this to my car and have already purchased most of the items I'll need for a 4 foot flame out of each tip.
My dads friend has it in his carbed NOMAD and its badass. He uses a propane tank and runs a few spark plugs gapped at 70 to do it. I'm buying the parts and he's doing the install this winter. I'll post a video when its done. It should be done by november-december. BTW the bumpers on our cars are plastic flex not rubber.
Whats the matter - doggie91z28 and the rest - cops dont show you enough affection???!!!
Acceleration = Adrenaline
[This message has been edited by highspeedfreak (edited June 27, 2001).]
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
Hello, Michael
Sep 11, 2015 01:10 PM
