Engine bay painting
Old Aug 27, 2008 | 08:24 PM
stick89's Avatar
Engine bay painting
So i'm in the middle of an lt1 swap motor and trans are out. So i have a bare engine bay and a color that i just don't like,the car is gray with a sky bluish colored engine bay,my final color is gonna be a shade of red. So my question is what should i do about the engine bay now i won't paint the car till the car is actually running and running good. (performance over looks ALWAYS)
Old Aug 29, 2008 | 09:36 PM
energycontacts's Avatar
Re: Engine bay painting
how hard was it to remove the a/c box? im in the process too, i think you should paint it first before you drop the engine back in.
Old Aug 29, 2008 | 09:48 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
what i did was just clean the crap out of it and hit it with some semi-flat high temp paint. plus it is easy to touch up. gives it that old muscle car look.
Old Aug 29, 2008 | 10:20 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
I am in the process of painting my engine bay now.I removed everything and used a drill and a wire wheel on most of it and a little hand sanding where it wouldn't reach.I also did the K-member and parts while I was at it.
I had planned on going satin black but I wanted to see what the gloss would look like also.Besides eventually the car will be black so I figured it will match better.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
