Rear hatch gas stain
Old Sep 2, 2008 | 04:19 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Ok, for the last year, I have had this chevy bowtie graphic put on my rear hatch. Its just a vinyl sticker. Now I decided to take if off, and even after washing and scrubbing and everything, once it drys, you can see where the old bowtie used to be. When its wet, you cannot see, but once it drys, its almost like the water stays where the emblem used to be. Ive cleaned it with soap, water, the works, mr clean scrub pad, you name it, alcohol, nothing. Please help?
Old Sep 2, 2008 | 04:47 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Rear hatch gas stain
Buff it out with some polishing compound, then give the whole panel a good coat of wax. It sounds like the sticker took off the wax from behind it.
Old Sep 2, 2008 | 04:49 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Well I guess Ill try that... I tryed goo gone, even though there is no sign of residue... Only when semi-dry, I tryed the potato trick, hmm... Maybe this will work... What I am really trying to do is restore the hatch, and get rid of those water drop marks as well
Old Sep 2, 2008 | 04:56 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I misread your original post, don't put wax on the glass... Polishing compound should still work to clean the glass though.
Old Sep 2, 2008 | 07:30 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
does it have like a white cloudyness to it? Caz my rear hatch and doors have this effect to them just over the ENTIRE window and i cant get it off. SO i was wondering to see if i can fid a remedy to my problem also.
Old Sep 2, 2008 | 10:15 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
No there is no cloudyness what so ever... Ok heres a little better explanation. Once you wash the car. Usually if you just let the back window dry, it leaves tons of drops of water there right? Well, all but where the sticker was has drops of water, yet there is nothing on the window, Ive felt it. No residue nothing. I mean its been thoroughly cleaned. And when I say all but where the sticker was, well theres a clearly defined trace out on my window of that sticker... You know what ill get pics tomorrow for yall lol
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
