Polishing Intake
Old Oct 21, 2008 | 04:08 PM
CKennels's Avatar
Car: 1989 Camaro IROC-Z Convertible
Transmission: Automatic
Polishing Intake
I just started to polish up the intake with roloc pads and removed the TPI tag and sand blasted it down, filled the pits, and painted it black shaving off the tops of the letters for a good chrome look. Planning on powdercoating the runners metallic blue.
Let me know what you think ;-)
Old Oct 22, 2008 | 12:25 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: Polishing Intake
It looks like you need some more work. There are plenty of threads about polishing on here as it is very possible to have a mirror finish if you are willing to put in the time to do the wet sanding. Search for "polish plenum" and you will find a treasure trove of info. Regarding the powder coat, if its done well that would look smooth.. might want to consider anodizing it also.
Overall, it looks like you've got a clean start. If you have the option, take the plenum off completely and polish from their rather than under the hood.
Old Oct 22, 2008 | 12:32 PM
Car: 1987 IROC Z
Here are some threads about it
https://www.thirdgen.org/forums/auto...tml#post766504
http://www.gmtips.com/3rd-degree/dox...m/pol-plen.htm
Old Oct 22, 2008 | 02:16 PM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Here's a pic of my polished plenum and runners I did in two days last winter.
Do it yourself (there's a tech article on this site...just do a search).
Good luck !!
Attached Thumbnails Polishing Intake-engine-bay-update-pics
Old Oct 23, 2008 | 12:03 PM
CKennels's Avatar
Thanks alot guys, I'll be getting to work on it tomorrow so I'll keep y'all posted.
Hotrodboba400
Dec 10, 2019 07:07 PM
Breazlan
Sep 25, 2015 11:20 AM
toronto formula
Sep 10, 2015 07:31 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
