Problems after h4 install
Old Oct 28, 2008 | 06:39 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
I just did the projector h4 conversion on my 91 z and im having a problem, when its just on the low beam setting my high beam is still lite up very slightly. Then when i switch to high beam it reverses, the low beam is very dim and the high beam is lit up. I havent made a new headlight harness and i dont really want to if i can avoid it. I want to keep the engine bay as clean as possible, any suggestions on why its doing this? thanks guys
Old Oct 28, 2008 | 06:47 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Re: Problems after h4 install
Think i figured it out, the h4 has a different plug layout than the factory light, so im prolly getting feedback from it.
Old Oct 29, 2008 | 06:03 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
you have to pull the wires out of the factory connector and rearange them and it will work fine...h4 uses a differ ground wire so thats why you have to switch them
Old Oct 31, 2008 | 05:49 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I had the same issue with some I ordered from ebay, turned out it was becasue the adaptor they gave me for them was switched around wrong, I re did the pins the correct way and they lit up correctly and when the lows are on only te lows are on, with highs they all light up bright but unfortunately it draws to much current from my system and blinks so a harness might be the best bet.
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
BLK87Z
Sep 18, 2015 11:29 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
