Window Tint
Old Jul 22, 2001 | 05:47 PM
89Irocz23's Avatar
Window Tint
hey I have a question about Window Tint My Iroc has this ugly purple tint and its peeling off and I want to know the best way to remove it. I tried to peel it off and it just tears and does not work. Alright thanx
Joey
Old Jul 22, 2001 | 05:57 PM
un4givin89's Avatar
get it retinted and have some pros redo it. My bros car had the same **** your talking about. When he took it to get tinted they removed the old stuff free of charge. Otherwise I beleive there is a chemical you can buy and using a window scraper should come off.
Old Jul 22, 2001 | 06:14 PM
89Irocz23's Avatar
alright thanks man thats what I wanted to do, but wasnt sure if they would charge a arm and leg to take it off.
Old Jul 22, 2001 | 09:29 PM
David Culpepper's Avatar
I had to have mine redone so I took it to a pro and he showed me how they do it. He said he has tried all of the chemicals on the market and none of them work. The only way to get it off is to scrape it off with a window scraper. If you have rear defrost it will end up being scraped off in a few places also.
Old Jul 22, 2001 | 11:21 PM
XxMoLexX's Avatar
nail polish remover... and a razor.. works pretty damn good.. jus try not to splash the remover around.. it will take some color out of the plastics in the car is sloppy.. i should know.. the sill plate on my door has a few "tear drops"
but other than that it works great
White 91 3.1 RS.
T-Tops
12" tube in the "trunk" (That hole they call a trunk anyways)
16" ROH Rims
Firestone Firehawks
BOSCH plugs and wires.
Energy Suspension Tranny mount and bushings
Old Jul 23, 2001 | 08:38 AM
purpleworm's Avatar
We just use the heta gun and some special solvent stuff to get the sticky stuff off. I know all the pro tricks now and does it ever make tinting a lot easier to learn form someone that does it for a living. I can do a perfect job now and it is so easy. If you are getting them redone use 3M or Lemco tint and you won't have the color problem again.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
