Need An Opinion On What To Do With Rust
Old Feb 28, 2009 | 10:49 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
No I'm not talking about that gut wrenching feeling you get when you discover your subframe is rotting out or your body is rusting through. I'm talking about that unsightly appearance of surface rust.
For example an area pretty bad on this is the shaft extending from the steering column under the hood.
What do you guys do to retain a pleasurable appearance? Paint these parts or use a rust converter and call it a day?
Old Mar 1, 2009 | 10:34 PM
toomany's Avatar
Re: Need An Opinion On What To Do With Rust
For just surface rust on a piece that is removable, I'll take it off wire wheel it and paint it. Or if it's real bad I'll just replace it. For something part of the body I'll wheel off the rust and put some Por15 or RustBullet on it. Either remove all the rust, or put a converter over it. Don't just paint it...it will come back with revenge.
Old Mar 2, 2009 | 11:52 AM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Like toomany said, the wire wheel is your friend. Follow that with a zinc primer and then paint. I've done hundreds of parts like that and they hold up well.
Old Mar 12, 2009 | 06:48 PM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
I have a ttop bar that has a very small rust spot. What do you think I should do to remove it? Should I just sand it down and then use zinc primer on it?
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
