How would I safely remove headlights without scratching paint??
Old Apr 18, 2009 | 04:20 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
K I'm probably going to be replacing my moms headlights soon and was wondering what is the safest way to take out the headlights WITHOUT scratching the paint.
She has a $5k paint job on this camaro so you can see why I want to be as careful as possible
Old Apr 18, 2009 | 04:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: How would I safely remove headlights without scratching paint??
Lay several layers of masking tape below the lamps.
JamesC
Old Apr 18, 2009 | 04:32 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Hm, true. lol
Old Apr 18, 2009 | 05:18 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Hm, true. lol
Make sure you only use masking/painters tape, other types of tape may leave the adhesive behind or could possibly damage the paint when you try to pull it off.
Old May 5, 2009 | 05:12 PM
riceburner247's Avatar
Car: 1992 Z28
I tucked a small rag under the light, then aimed the light all the way up. Removed the top 2 trim screws and pulled the trim peice forward enough to get the light out. There may be a better way to do this, but I found that to be the easiest way for me.
Old May 14, 2009 | 04:46 AM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
Use a low adhesive tape like charcoalbird said, when i redone my car i drilled holes from the inside so i could screw and unscrew them, makes it easier.
Old May 18, 2009 | 02:59 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I put one of those buffing clothes down in the bucket area. Never had a problem scratching paint that way.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Wife'sCar
Aug 22, 2015 01:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
