Clay bar for paint.....
Old Aug 2, 2001 | 09:53 PM
rondubbs's Avatar
i like this stuff a lot but its expensive, i was wondering if i could substitute "playdo" or something cheap like that.. will this work to get the dirt off?
Old Aug 2, 2001 | 10:33 PM
cobrakiller1989's Avatar
Yes, you can use play-doh. And if you dont feel like spending any money on play-doh, than you can make a big bowl of dirt with extra rocks in it to remove extra scratches from your car. I do it all of the time.
just kidding, please do not try this.
On a serious note. I dont beleive that you can use play-doh
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Aug 2, 2001 | 11:20 PM
Unmarked Vehicle's Avatar
When I first bought mine, it was expensive...especially at the time where people hardly used them.
At the end, the cost did not matter at all when you end up with the results it gave. It's not like you only use it once. You can use that bar many many times...provided you take care of it.
You will only be spending money on the lubricant...which you would probably need to buy anyway with the play-do.
I've used Clay Magic and Mothers. I prefer Clay Magic.
Old Aug 3, 2001 | 12:28 PM
rondubbs's Avatar
but what im asking is that the clay in the kit is regular stuff, not some "magical" clay. so any clay(playdoh) can substitute it right? ?????????
Old Aug 3, 2001 | 08:05 PM
Jza's Avatar
Jza
playdoh has salt in it. you wanna rub salt on your car?
Old Aug 4, 2001 | 12:46 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Just what are the proper steps to using the Clay Bar?
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 4, 2001 | 02:00 PM
Brad91Formula's Avatar
For sarters not all claybars equal. The best two claybars on the market that I have seen so far are Zaino and Mothers. Claying is very simple to use and very effective that will leave a smooth clean surface if used properly. The key to getting good results is to keep the area you are working on well lubricated with a water and soap mix. I use a spray bottle for application and just do small areas at a time. Just glide the claybar across the surface don't use a lot of pressure, let it do the work for you. Also never work on a hot surface this can cause bad results.
'91 Firebird GTA L98, 700R4
'91 Firebird Formula L03, T5
'93 S10 Blazer L35, 4L60E
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
