wheel paint question
Old Jul 21, 2009 | 02:03 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I got my wheels stripped and repainted. Do i need to spray clear over the painted part? What about the rest of the wheel, does it need cleared?
let me know
Old Jul 21, 2009 | 02:05 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: wheel paint question
I believe that it does...but more knowledgeable people will chime in...
Old Jul 21, 2009 | 04:23 PM
Krik's Avatar
Engine: 5.7 TPI
the black needs cleared, or the whole wheel?
Old Jul 21, 2009 | 05:20 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i had a black 91 with black painted inside of the spokes. the entire wheel had a darn fine clear coat on it. my 90 is all clear boat even though its not painted. i suggest you get A VERY GOOD clear coat - they will not discolor.
that is my 2 cents.
Old Jul 21, 2009 | 07:52 PM
bsporty's Avatar
Car: 85 Z28
Transmission: 5 speed
What kind of paint is it? Is it a base/ clear or enamel?
Old Jul 21, 2009 | 08:57 PM
Krik's Avatar
Engine: 5.7 TPI
enamel
Old Jul 21, 2009 | 09:49 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
let me know
Depends on how hard you want to work at keeping the machined surface clean. The set of 15" Z28/RS wheels I redid were red with a clear coat over the entire wheel. When I finished, I all the red sections were black with a clear coat, and I left the unpainted surfaces bare. Those wheels ended up on a friend's S-10 pickup.
Old Jul 21, 2009 | 09:58 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
I refinished my rims about 7-8 years ago and I clear coated the whole rim. I think its easier to Keep clean and Too clean, if left bare you'll need alot of metal polish, and use it every time you wash your car....
Old Jul 22, 2009 | 07:00 AM
Krik's Avatar
Engine: 5.7 TPI
If i don't clear them, then I have to wax them to protect the finish?
Old Jul 22, 2009 | 09:35 PM
Krik's Avatar
Engine: 5.7 TPI
bump
Old Jul 23, 2009 | 10:32 PM
Al Hasse's Avatar
Take care of them like any other painted surface, even if clear coated. But if you leave the machined surfaces untouched, then you need the metal polish there.
Old Jul 23, 2009 | 10:39 PM
Car: 87 T-Top GTA
And you should also use a sealer after using metal polish,(shine will last longer). If clear coated, use soap 'n' water..... NEVER use rim clearer on clear coat...happened on another car, not my GTA....thank god!!!!! It F***ed those rims right up...
Old Jul 24, 2009 | 06:40 AM
Krik's Avatar
Engine: 5.7 TPI
I have already stripped the clearcoat off of both my practice wheels. I have polished and painted one and it looks amazing! once i figure out what I am doing i am going to do my car's spare set of wheels.
Polishing clearcoated wheels can be fixed by removing the clearcoat. They are not ruined.
Old Jul 24, 2009 | 03:44 PM
Car: 87 T-Top GTA
So are you polishing them first and then clear coating the Whole Rim, or just leaving it bare(painted center and polished outer rim)????
Old Jul 24, 2009 | 08:16 PM
Krik's Avatar
Engine: 5.7 TPI
Stripping
Polishing bare metal
masking and painting
yjos is where I am at now. I havent decided if i want to clear coat them, or just wax them.
Old Jul 27, 2009 | 06:32 PM
halostryker's Avatar
Car: 84 Camaro z28
Engine: 305. LE9
Transmission: 700-R4
Axle/Gears: 3.42:1 Locking
I would just powder coat them then you wont need to worry its a win win.
Old Jul 27, 2009 | 06:57 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
if its a DD then clear coat them, if its a plesure car then no clear coat but you better keep a good sealer wax on them
another option, if you are polishing the entire wheel strip all the paint off and take them to a local truck stop (you may have to try a few) but anyway they got aluminum polishing guys there, they can take alum that looks like grey primer and make it look like chrome, and they put a sealer on it that will last a year on a tractor trailer, now thats atleast a hundred thousand miles and in bad conditions......ask them about the shine warranty the guys who did my alum on my truck had a 1 year, most guys offer about 6 months to a year, i would figure it would last alot longer on a 4wheeler (car lol) than a tractor trailer since its not near the miles in a year
Old Jul 27, 2009 | 07:30 PM
Krik's Avatar
Engine: 5.7 TPI
i'm not going to powder coat them, i like the way they are turning out painted. I like the idea of waxing them, i was pretty much just looking for someone to valadate the idea anyway.
Thanks for the imput guys. Any more comments will be welcome.
Old Jul 29, 2009 | 10:58 PM
Car: 87 T-Top GTA
Are you asking about, waxing the painted part? Using sealer wax on the polished part of the rim?
Old Jul 30, 2009 | 09:11 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
I stripped my iroc 16 inch wheels. polished them taped them off. painted the insert area. then removed the tape and cleared the whole wheel with a rattle can rim paint and clearcoat from autozone. that was a year ago. and they still look new. good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
