Making factory teal with rustoleum
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Making factory teal with rustoleum
using rustoleum as car paint is like using ziploc baggies as condoms, takes a bit more work to look the same but works just as good. right?
did you price duplicolor? thats made for cars. and has a way better chance of looking good.
did you price duplicolor? thats made for cars. and has a way better chance of looking good. Member
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
I've painted a lot of stuff with Tremclad. I would advise against using the Wagner Power painter and stick with the roller. I will cost you less and will probably give you less headaches. Will take a bit longer.
If you're dead set on spraying pick up a cheap hlvp gun and borrow/rent a compressor.
Do a bunch of small test batches to get the colour you want. Be sure to gently mix the paint together so yo don't get air bubbles.
Its great paint and if you do the prep properly and do the sanding well most people wont be able to tell the difference.
The paint goes inert after a while so you should be able to paint over it with a "professional" paint job when you have the money. Just need the right primer.
Another alternative to Rustoleum is boat paint. I'm in the process of rolling one of my cars with Brightside. Its a little more expensive, but those who have tried both, say it goes on easier and is glossier. Its probably more durable than Rustoleum as well.
http://www.jamestowndistributors.com...duct.do?pid=64#
I am getting ready to get real serious and have some money saved up to finally spray with rustoleum...
Has anyone experimented with mixing rustoleum to make something similar to the factory metallic teal look. I aint looking for perfect match but something that will kinda look decent with the door jambs and all. I know green and blue but just wanted to see if anyone has already tried to figure out the correct mixture.
I didn't like the yellow that was available with the paint I used, so I got some white and started experimenting. I used a q-tip and and mixed 1 drop of white to 7 drops of yellow, then 2 drops of white to 6 drops of yellow and so on until I had 7 different shades. Once you come close, you can fine tune it from there with more precise measurements.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
novaderrik
Aug 10, 2015 12:44 PM
