Can Pro Tint job be removed from doors?
Old Aug 17, 2001 | 12:32 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I may want to remove the tint from the door windows and replace it. It is starting to look scratched, etc. Can the Pro shop I had it done at remove it and replace with new tint? Has anyone ever done this?
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 17, 2001 | 11:20 PM
David Culpepper's Avatar
The place you had it tinted at should be able to remove the old tint and retint it. I just had to have mine removed and retinted. Shouldn't be a problem on the sides, the hatch is a different story. They just use a window scraper with a fresh razor blade in it to scrape the old off.
Old Aug 18, 2001 | 12:38 AM
slowmaro92305's Avatar
if u want to remove the tint urself...get some windex and a sharp razor blade. soak the window with the window and scrape off the tint.
Old Aug 18, 2001 | 06:03 AM
Axle/Gears: Posi
Thanks guys. I may leave it for now since I know it can be done easily, but come winter time while in hibernation in the garage off it comes so I can have that fresh look in the spring.
BTW, the main scratched area seems to have come from the 2 screws that hold in the arm rest. You see a few weeks ago I put on new door panels and ever since the glass has started to get scratched(same place, both doors) where the screws are when the window is down. All I could figure is I put the screws back in tighter than they originally were. Anyone ever had this problem?
[This message has been edited by 86NiteRider (edited August 18, 2001).]
Old Aug 22, 2001 | 11:11 PM
89RustangRemover's Avatar
<font face="Verdana, Arial" size="2">Originally posted by slowmaro92305:
if u want to remove the tint urself...get some windex and a sharp razor blade. soak the window with the window and scrape off the tint.</font>
I've never actually tried soaking a window with the window...but I guess it might work
(sorry fellas, couldn't resist )
Old Aug 23, 2001 | 07:08 PM
jm91rs's Avatar
I took off the doorpanels, peeled off the tint with a razor blade and then I used brake fluid to remove the glue. don't get any on the paint, but it removes the glue awesome. use a hair dryer when pulling the tint.
Jeremy
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon...non red interior with 4th gen charcoal/grey seats
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
