Painting The Front Bumper
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
Jus Got A New Front Bumper And Was Wondering The Type And Grits Of Paper You Would Use To Start Sanding It Down....Thanks
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: Painting The Front Bumper
Finish with a 180 or 220...I prefer finishing with a finer 220 grit. Prime and paint. You basically don't want to be too smooth or too course...too smooth paint may not stick/bond as well, too course and well, sanding lines can bleed through.
Car: 85 Z28
Transmission: 5 speed
Does the bumper have spider cracks?You will need to use 180 to sand them out then you will need primer.Then you can either block with 180 and reprime or sand with 320,400, and 600 wet and then paint.
Be sure to get some adhesion promoter for any raw plastic areas.
thanks for the help guys ill post up a couple pics when im done with it jus really wasnt sure about that plastic the bumper is in waaay too good of shape for me to ruin it thanks again
1992 Trans Am
May 10, 2023 07:19 PM
