How wide can I go.....?
Old Oct 13, 2009 | 09:48 AM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I have figured out the wheels I am puttin on my TA, now Im into tire sizes for the front. THe front wheel is a 19x8, but the manufacturer(Bonspeed), says the wheel is more like a 9inch wheel. Do u think that with a 2" drop I could fit a 255/35/19 underneath the front corners and survive. Godspeed has 255/40/18 on his front end and his tire diameter is about the same as mine, plus he has coilovers that sit just over the rim and tire,which leads me to believe he is lower than just two inches. Just wanted to get some input from you guys before I went out and bought the tires. Thanks.
Old Oct 13, 2009 | 10:04 AM
Stephen's Avatar
Car: 87 GTA
Re: How wide can I go.....?
You can do that easy as pie!
I'm running 275/40R17s, with ZERO mods to the wheel well. The tie rod end is less than a inch from the rim edge & if mine were 19s, I could run even deeper backspacing & go to a wider tire!
What is you plan for the rear wheels & tires?
Old Oct 16, 2009 | 12:46 PM
Copchaser's Avatar
I am runnin 19x10 in the rear with a 295/30 tire.
Old Oct 19, 2009 | 04:47 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I have 17x9" wheels wrapped in 285/40/17 tires up front and I have a 3+" drop, I think you'll manage.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Vincent135
Sep 28, 2015 10:50 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
