Removing window tint
Old Apr 7, 2010 | 08:32 PM
ss3964rat's Avatar
Car: 1991 Z28
Does anyone have any tips on removing really old window tint from the rear hatch glass with out completely destroying the glass and defroster?
Old Apr 9, 2010 | 07:46 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Re: Removing window tint
Brake cleaner works ok.. but i recommend rubbing alcohol for the glue. stay away from that worthless wal-mart tint remover. that is exactly how i did mine!
Old Apr 9, 2010 | 08:05 PM
ss3964rat's Avatar
Car: 1991 Z28
Thanks, I will give it a try.
Old Apr 9, 2010 | 08:06 PM
Stephen's Avatar
Car: 87 GTA
I suggest trying this first..... TGO link
Old Apr 9, 2010 | 08:20 PM
mrsupermexican's Avatar
Car: 86 IROC Z28
Engine: 355 w/750cfm Weber
Transmission: 700r4 auto
Hi, this is my first post so I figured I'd spend it on something I'm experienced in. I recently got an 86' IROC Z and it had a terrible tint job done on the hatch glass. My first car (an 01' Celica) had too dark of tint for my state and as a result I received a wonderful ticket for it when stopped by a local cop. After that I learned that a safety razor will very effectively remove difficult tint.
They look like little metal sticks of gum and you should be able to find them in the brief hardware section your local pharmacy for about $2. The blade will be a single edge little thing that slides into the side of the holder, but you can split the tip of the holder to put the blade in sideways as a mini scraper, about 1" or so wide. This is very hand for tight spaces, and the sharpness of the blade ensures you get everything.
Get some black trash bags and windex, spray the tint very thoroughly with windex and tape those trash bags up around the glass, and let it sit for a while (30min to 1hr). Pull it down and scrap away.
Be careful of the heater lines with the scraper, usually you should be able to scrap before the lines and pull the tint in strips off and away from the heater lines.
Hope this was helpful! I've done this on three cars, the Celica, my "new" z28 and a friend's eclipse. Good luck!
Old Apr 9, 2010 | 09:48 PM
ss3964rat's Avatar
Car: 1991 Z28
Thank you, I will give it a try
RyanJB
Sep 2, 2015 01:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
