I found an 89 formula in the junkyard yesterday, and it has the aero spoiler. Its in bad condition, the rubber is tearing on the passenger side corner, and it it sort of wavy. The good thing is the jankyard is only asking $25 for it. Is there anything I can buy to fix this? Is it possible to use bondo to fill in the cracks. I am good at body work, I know I can get it smooth but I dont know if bondo and spot putty will work on rubber. Will it crack over time? Also, I have heard of a flexible bondo which is meant for rubber bumpers like ours. Would this work?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
1983 Firebird
TH700R4 Auto
Small Block 400
Jim85IROC
close
Ever hear the phraise, "You can't polish a turd"? It applies here. You can put all the filler you want on it. It's not going to prevent the rubber from continuing to deteriorate.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
