Nightshaded my tail lights pics inside
Subscribe
May 16, 2010 | 05:13 PM
Decided to tint them out this weekend. Here's some pics. 3 coats of nightshade and 4 coats of duplicolor clear. I went with the idea of laying thick heavy coats to keep it glossy which just settled and died down to a flatter typical VHT look , so I took clear and applied heavy wet coats the key is to keep the clear wet looking without leaving drip marks same as if your painting a car.
Reply 0
May 16, 2010 | 05:16 PM
Re: Nightshaded my tail lights pics inside
gotta say it looks pretty nice! there isnt many of these tailight tinting jobs that i like as most come out really dull looking but yours is nice an glossy.
btw your car looks bad azz with the drop i wanna do a 2in or so drop on my IROC-Z but no way with it gonna be a daily driver.
Reply 0
May 16, 2010 | 05:24 PM
Quote: btw your car looks bad azz with the drop i wanna do a 2in or so drop on my IROC-Z but no way with it gonna be a daily driver.
Thanks, the two inch drop is extreme and the ride kinda sucks but the look is well worth it. Factory F-bodies look like trucks in comparison. I do get comments like "damn thats low" in person. This car is also daily driven in the spring/summer through rain or shine.
Reply 0
May 16, 2010 | 05:27 PM
ya i use to think my camaro was extremely low (I still think its still fairly low) (maybe its sinking springs?) but compared to some its an major diffrence from stock to a few inch's dropping. i think if i do lower it any it will just be an 1in drop.
Reply 0
May 17, 2010 | 04:17 AM
liking the taillights! nice job!
love the car as a whole..
Reply 0
May 17, 2010 | 10:02 AM
That looks sharp!
Reply 0
May 17, 2010 | 11:06 AM
Looks nice!
Did you wetsand and buff them as well?
Reply 0
May 17, 2010 | 01:23 PM
turned out great
Reply 0
May 17, 2010 | 02:56 PM
that looks badass
Reply 0
May 17, 2010 | 03:25 PM
The only thing I did to prep these was wash them with dish soap and scrub them with the finest steel wool from home depot I actually used the same soapy water while I did this which dulls them out and makes for a good surface for paint.The idea to get it so glossy is to lay the clear kinda thick so it looks glossy the trick is to not get runs which was pretty easy but then again I have had practice.
I have yet to put any type of coating other then the nightshade or clear. I imagine when I do they will be even more glossy. They just look like dark factory tails in person and appear to be stock.
Reply 0
May 17, 2010 | 09:04 PM
I didnt think it was possable for your ride to look any sexier...but damn...she is lookin awesome! Good job!
Reply 0
May 17, 2010 | 09:18 PM
Quote: I went with the idea of laying thick heavy coats to keep it glossy which just settled and died down to a flatter typical VHT look , so I took clear and applied heavy wet coats the key is to keep the clear wet looking without leaving drip marks same as if your painting a car.
I tried that too with the same results. Ended up doing much the same as you did. 3-4 very light coats of VHT over the lenses followed by 3 thick coats of clear. Mine aren't a total black out as I wanted the colors of the lenses and the reflector to show through.
Reply 0
May 18, 2010 | 06:13 AM
Quote: I tried that too with the same results. Ended up doing much the same as you did. 3-4 very light coats of VHT over the lenses followed by 3 thick coats of clear. Mine aren't a total black out as I wanted the colors of the lenses and the reflector to show through.
That looks almost exactly like mine.
I used 4 thin coats, 4 coats of clear then wetsanded with 1500 grit, then buffed them out with a foam wheel and some fine cut compound. I might be able to get some pics but the car hasn't been washed in years so the tails are the cleanest thing on it.
I also did the front side markers, they look pretty good on a dark car.
Reply 0
May 23, 2010 | 12:28 AM
i just did my trans am lights too, just got them for 50 bucks. but i taped off the reverse lights so they wernt dimmed any. they turned out nice, just got to figure out how to wire them in my firebird
Reply 0
May 23, 2010 | 11:42 AM
damn. came out good and i like your head lights. now you got me thinking about doing mine!
Reply 0
May 23, 2010 | 03:35 PM
Beautiful car Wraith. Nice work
Reply 0
May 23, 2010 | 04:34 PM
vht? and i like the fact another 3rdgen with a cb antenna
Reply 0
May 27, 2010 | 05:55 PM
Looks great!
So you used Duplicolor Clear Enamel?
You think that clear with hold up to a polishing agent and a wheel?
And you sprayed the outside right?
Did you do the center section as well?
Could you possibly post a pic at night with your brake lights on?
I'm curious to see how visible they are
Sorry for all the questions, i'm just thinking of doing this.
Reply 0
May 27, 2010 | 07:08 PM
Yes not even half the can.
Quote: You think that clear with hold up to a polishing agent and a wheel?
I don't see why not, mine didn't need it though. I have seen people use a polishing wheel on tremclad so it should be ok. It's hard as a rock now.
Yes
Quote: Could you possibly post a pic at night with your brake lights on?
Yeah just have to wait till the weekend. I'll get a pic. They are still very visible when lights are on/signaling in the daytime.
Reply 0
May 27, 2010 | 09:04 PM
Thanks for the quick replies!
I'm stoked to do this. And i'm assuming to do the marker lights is the same hey? Except i'm gonna sand down the lettering. But I can't wait to see the pics!
Reply 0
Aug 4, 2010 | 10:50 AM
Probably my fav bird on this site...car looks better everytime u post...between ur job and Mikeys, im definately gonna have to join in on the vht
Reply 0
Subscribe
